biggest print size?
umcelinho
Marcelo
8:45 AM
Hi, which is the biggest print size anyone here has done?
I'm about to print in 90x60cm, hopefully it will be okay...
I'll post results afterwards.
No idea with the RD-1 but I have printed A2 from both a 6mp 10D and an 8mp 590A. Looks fine until you stick you nose close to the print at which point it is, well, a bit blurred. Seen at a distance (+30 cm) I am sure your 90x60 will be fine.
I've had some nice 11x17" RD1 prints done through adorama. I used Lightroom for adjustments and final file creation.
Thanks, guys, I am really asking about printing from R-D1/s/x files (thus posting this here on the R-D1 section).
Both R-D1/s/x files and the scans I get from the lab are 6mp, 3000x2000. To get a file in 90x60cm (36x24in) I had to interpolate and more than triple the dimensions in pixels. Then in Lightroom I added a small amount of grain to mask the interpolation artifacts. I think it came out acceptable. The prints won't have the same definition as a 20mp native shot (that my RX100 does), but considering the size and the viewing distance it might be okay.
As soon as I have the images printed I'll post the results here.
The same, :)
interpolate twice to get 24Mpx,
sharpening with the biggest radius at a very low setting (enhance local contrast and not pixels)
then add a "film grain" like.
Good result at a viewing distance > 1m
