johnnyrod
More cameras than shots
I need two new blades for a Copal SV shutter. This is on a Konica S which ic lovely and otherwise working, even the selenium meter, but two of the blades have been damaged in a coming together. Unlikely as this might be, any ideas where I could get two more? Failing that, anyone want an almost-working Konica S with Hexanon 48mm f1.8?
View Range
You might try SK Grimes in the US, assuming that a variety of Copal shutters use the same blades. But it might be cheaper to find a non-working Konica S on e-bay.
xayraa33
rangefinder user and fancier
Many other cameras used the Copal SV shutter, including the Canonet, Yashica Lynx 5000 and the Yashicamat TLR and many more camera brands.
Do your research and you can pick up a parts camera off Ebay for not much money.
johnnyrod
Thanks for the replies, I haven't contacted Grimes yet but have been trying some other avenues, so far in vain. There are indeed a great many Copal SV shutters out there - but such a variation right up to large format that I've found it impossible to figure out which cameras use the same shutter, as in, similar enough to be able to use the parts. So I'm still looking, any info would be helpful, otherwise anyone is free to ask me about buying this one to fix their own, or have a go themselves.
johnnyrod
Well so far I'm turning up nothing at all on this, any thoughts would be greatly appreciated.
xayraa33
You can buy a beater donor Konica S for around 33 US dollars with shipping if you are in doubt if other Copal SV shutters on other brands are not the same as the Copal SV shutter on your Konica S.
http://www.ebay.com/itm/1959-KONICA...394271?hash=item25b4388a5f:g:-hsAAOSwcwhVNT8M
johnnyrod
Good find! None of those in the UK alas and the shipping is horrendous.
From what I've seen on t'internet the Yashica Lynx shutter has the same blades, but none of those going cheap right now. I am trying to find out if the Electro is the same too, any ideas anyone?
btgc
Electros have straight edged blades, change from Lynx 5000.
johnnyrod
Ah, thanks. I guess I'm stuck trying to find a Lynx or Konica. Any Lynx I wonder?
Crazy Fedya
http://www.rangefinderforum.com/photopost-classifieds/showproduct.php?product=48877
There is both Lynx and Konica S listed in this ad. Good luck!!
xayraa33
13 dollars shipping from Canada to the UK is not horrendous or unreasonable.
It is less than the cost of 2 visits to the coffee-shop with the mermaid logo.
Plus the same model of camera will give you many spare parts for future use.
johnnyrod
xayraa sorry but I couldn't see the shipping to UK cost on the ad? As you say $13 isn't bad
Thanks for the link Crazy
johnnyrod
Well I'll close this off in case it's useful for someone else. I eventually landed a real beater of a Beauty Lightomatic II, maybe 90% of it, which had the required bits. It was still a bit of a job (read: epic struggle of Titanic proportions) but it's now back together and just needs collimating etc. Thanks all for your help, I'm hoping it's worth the trouble!
