kevin_v
So... I had a sudden nosebleed with my M3 around my neck, and a drop fell around the shutter release. Some of it got in and around the space between the release and collar. I cleaned it up as well as I could, but I'm sure there's still some in there. So, should I worry?
Jobin
I think you're fine.
johannielscom
Snorting silver salts
Worry about nose bleeds, but not about the camera. It'll be fine, nothing worse than a single drop of rain.
OlliL
It'll probably dry and fall apart.
But how's your nose?
Vincent.G
I thought it was used as a murder weapon when I saw the title...
kevin_v
But how's your nose?![]()
Thank you for asking... currently, I have two pieces of tissue paper rolled up in my nose (one started shortly after the other stopped), but I think they've both stopped. Yesterday, I somehow coughed through my nose (not sneezed) and I've been having nosebleeds a bit more frequently... I guess I need to be a bit more careful where I put my nose...
cjbecker
Stop worring about your camera. Its a tool.
---f
allergy season will do that.
kevin_v
Yes, yes, I know. I made sure to take care of myself before bothering about my camera... Thank you, though.
BobYIL
Do not even mind about the camera, once a drop passes through the shutter release collar it will spread around and dry on the first surface to leave a residue to have nothing to do with the functions (it's not like oil to seep everywhere..) However, if you are over 50 have your blood pressure checked time to time.
FrankS
Registered User
Your DNA is inside the Leica. Now you will be assimilated. Resistance is futile.
Gumby
The camera is now a biohazard. It must be disposed of properly... and promptly.
chodgson45
Grain is Good
It just so happens I am an "authorized" disposer of Bio-hazards. Please send your M3 and I will properly dispose of it
