awilder
Alan Wilder
After recently purchasing the Konica 35/2 UC, I compared it to my 35 Summicron ASPH. and was surprised to find a virtually identical fingerprint in terms of bokeh. Unfortunately, I no longer have the pre-ASPH. version for comparison, but I strongly suspect it differs in bokeh from these lenses in that there is less blur in the OOF regions. The pre-ASPH. v4 was known as the "King of Bokeh" because "it's coherence of OOF imaging can trick the eye into seeing greater sharpness than exists" (after John Kennerdell, Photo Techniques, May/June 1997). Anyway, here are some images. The first two are at f/2.4, ASPH on the left and UC on the right. Slight color differences are due to changing sunlight.
awilder
Alan Wilder
aizan
try focusing on something closer. that'll show up much better.
awilder
Alan Wilder
awilder
Alan Wilder
Sorry, the shots at f/2 were the closest, I think around 5 feet.
wintoid
Back to film
Just a comment... in the shots at f2, I can see the slatting of the shed walls on the Hexanon shot, but it's mulched into the bokeh on the asph.
awilder
Alan Wilder
You are correct about the f/2 shot. Actually, the large OOF area to the left of the tree is the brickwork on the side of my neighbors house. The lighter mortar, especially in the vetrical direction, stands out more with the UC compared with the softer OOF quality of the ASPH. This surprised me initially because I expected the UC to have the softer bokeh. I think it may have to do with the ASPH. correction being so good that more light rays are brought into focus at it's focal plane.
Gabriel M.A.
My Red Dot Glows For You
The differences in lighting between each shot make this hard to assess, but after taking a closer look, I can't believe I like the 35 ASPH better.
awilder
Alan Wilder
I tend to agree about the Summicron ASPH. OOF quality. The difference is subtle but it seems a just little softer than the Hexanon UC.
clintock
Galleryless Gearhead
Do you have a CV Ultron 35/1.7 to compare?
galavanter
I'm glad to see the more than twice as much Asph also displays some double lines.
I was not familiar with this phenomenon until member ferider pointed it out in the other UC thread. In the F2 shots, in the top left corner of pic, it is more apparent than the UC.
I am thrilled with the results from mine, not only visually but ergonomically too. I may even get used to the tab, so very well built are they. I'm surprised to see one still available from Matsuyiastore. I would think the M8 owners in particular would be all over these.
mfunnell
Shaken, so blurred
They must have cornered the world's supply of them, then decided to release them one-at-a-time to keep the price/interest level up. (Which seems to have worked.) They must have sold at least 10 recently (mine is #991).galavanter said:I'm surprised to see one still available from Matsuyiastore.
...Mike
raid
Dad Photographer
Maybe you will be inspired to contribute a 35mm lens to this:
http://www.rangefinderforum.com/forums/showthread.php?t=38002
We already have twenty five 35mm-40mm lenses.
Raid
Raid
ferider
Thanks a lot for the comparison.
I agree and I like the UC better.
Branches and leaves in the background are the most difficult OOF subjects ...
Best,
Roland.
galavanter said:I'm glad to see the more than twice as much Asph also displays some double lines.I was not familiar with this phenomenon until member ferider pointed it out in the other UC thread. In the F2 shots, in the top left corner of pic, it is more apparent than the UC.
Best,
Roland.
Avotius
Some guy
I like the 35 asph better too, the over all image is better as well, things seem pretty tidy with that lens, one that I hope soon to add to my working bag.
awilder
Alan Wilder
Unfortunately, I won't be able to do anymore bokeh comparisons as I just sold the Summicron ASPH being sufficiently satisfied with the UC. Sharpness is better than I expected. Sharpness is much closer to the aspheric version than the pre-aspheric v4. I really liked the UC's size and build quality.
raid
Dad Photographer
This is a very interesting finding for people who are considering buying either of these two 35mm lenses. The cost difference is not small. Right?
Raid
Raid
awilder
Alan Wilder
I paid $850 w/ used M adapter. The Summicron ASPH. goes for typically around $1300 in nice condition used. The biggest advantage of the Summicron is better corner sharpness and close focus a little below 0.7m vs. exactly 0.9m on the Hexanon UC. I also prefer the Summicron's hood design because it's more compact, rectangular and has it's own cap. The UC has the larger round vented style which dwarfs the tiny lens when attached.
espressogeek
They are both KICK BUTT. I have the UC and its good enough for me! Thanks for the comparo!
venchka
If your camera inventory supports both mounts and the wee Konica lens is less expensive.......
You don't have to be smarter than a 5th grader! Hurry up USPS!
