Bromide-drag / Scanner-fault ? [photo]
maddoc
... likes film again.
4:47 PM
A question for the experienced member who are self-developing their BW films. The following frame is one of two frames form a single roll of FOMAPAN200 135-36 (not expired), developed in HC-110 "dilB" at 19 degrees C for ~ 4 minutes (to short to get really reproducible results, I know ...) with initial 20 inversions and then 3 inversions every minute (my standard procedure). Only change form my normal procedure was fixing-solution, so far I used Ilford-Rapid fixer now I use Chugai "MyFixer" (Japanese Maker).
Are these dark areas "bromide-drag", uneven development or result from insufficient fixing (fresh fixing solution was used) or probably a scanner hick-up ?
Any tip highly appreciated ! :)
