Bronica RF645
leicam
3:30 PM
I have just received an used Bronica RF645. The rangefinders vertically alignment need to be adjusted. Anybody who knows if this is an relatively easy do-it-youself job?
The horisontal alignment is a simple task, but I can't find a similar place to adjust it vertically.
Thanks for your reply.
I think it is too expensive to send it almost half the way around the globe to fix it. I will rather try to find someone closer to where I am located. Else, I have to try to live with this. Of Course, if it is not a way to fix it by myself.
leicam said:
Hello,
The vertical alignment on my RF645 was also slightly off when I got it. I found that things improve if you place your eye slightly lower in the viewfinder.
Monz
