Bruce Gildens Flashgun; What is it?
Benjamin
Registered Snoozer
10:57 AM
Surrey, England
Hi, does anybody know what flashgun Bruce Gilden uses, purely out of interest?
It's pretty massive, and he holds it in his left hand with a sync cable to an MP I think. You only get 1/50's flash sync with an MP right?
Thanks,
Benjamin
P.S. Merry Christmas x
Anyone seen Mark Cohen video where he also uses a flash? I'm trying to figure out how he does it...
How does one use a hot-shoe cable connected to a flash? Which flash cable do i get to connect from a M4-2 to a flash. I have that tiny screw that blocks the flash from going all the way in. I'm trying to connect a Olympus fl-36 and it randomly engages the flash during wind-up etc...
Use off- camera flash, a heavy flash can damage the flash block (causing intermittent flash firing or worse jamming the shutter.)
Get Paramount sync cords (model type depends on flash) or remote trigger.
What cable do you guys recommend? A PC to hotshoe cable?
I am looking at an Olympus S20 flash right now which looks like it would do the job.
Just a week or so after Gilden's (in)famous video appeared on youtube I saw a guy here in Toronto with a flash attached to a small retracted monopod and he was using the flash with a DSLR in broad daylight. However, the interesting part was that he was using the flash raised and pointing downwards... I guess he wanted to acentuate the vertical light that you get anyway during daylight. 😉
His book "Grim street" is indeed interesting, but seeing him working left me a bit disappointed....
I just got the book as well. I have some favorites in there... how so did he disappoint you? just wondering. I'm not sure if there's a "good" way of approaching a street/strobe photography.... or maybe its because at least Gilden looks thru the view finder and Cohen doesnt...
I'm pretty sure that I posted something here in the last week or two about how to make an external battery pack for the Vivitar 283 and 285 flashes. It uses 4 D cells, which have about 4 times the capacity of AA cells. Also the AA cells heat up when you shoot fast and the heat kills them. D cells only cost about twice as much as AA cells.
