Buying a Leica-ready Jupiter lens
Redseele
2:14 AM
I feel bad about asking about this but here it goes: does anyone know where I can buy a Jupiter 3 or Jupiter 8 lens that is already shimmed to focus correctly on Leica bodies?
I've read the guides, but for the life of me I've ruined lenses in the past and I'd rather not do this kind of work on my own.
Any suggestions would be greatly appreciated.
Question is what is it worth to you ?
Four safer ways to do it:
1) get a serial # under 52xxx (that's what I have)
2) get an Amedeo adapter and a Contax Jupiter
3) get a Canon 50/1.5 instead - if you are OK with a couple of optical imperfections, this should be around or less than US 300.
4) get a Lomo Jupiter-3 instead.
Then again, all the above might be too expensive to you. Maybe get a chrome Canon 50/1.8 instead ?
Roland.
I think Roland covered it pretty well.
I'd add that I bought my 1954 (or is it 1957?) Jupiter-3 from a fellow RFF-er who already shimmed it for me (thanks Jan). Just want to mention that's another option. You just have to wait, ask, wait, ask, but eventually you'll catch someone with a shimmed lens he/she will sell ya.
There was another thread here lately about a new Lomo product, in that thread was a tad of discussion about the new Jupiter-3 lens. I don't have one, but I heard they were darn good. I think they're something like $600
As for serial number under 52xxx, I don't know if that holds for J-3, J-8, or both.
Yes, the Jupiter 3+ looks very good and I would consider it were it not for the fact that it's sold out everywhere. I think it was a limited run. Buying a Russian or a Zeiss Jena lens with the Contax-Leica adapter is beginning to sound like an interesting idea.
Thank you for all the feedback so far.
There was someone on the forum who did this work. I can't think of the name at the moment, but it will come to me--or--
OK, it's Brian Sweeney. He might be findable here, or over at photo.net. Oh, and There's John Van Stelten at The Focal Point in Colorado. I think they are both googleable. I would hold out for what you really want. You want a Jupiter, get a Jupiter!
Try Fedka dot com. He sells lots of Russian stuff and is supposed to be good. He has a choice of new or old for around $50 for a J8. For a little more buy a Canon 50mm f1.8, a very fine lens. Good Luck. Joe
Yes, I've heard of him... but I have no idea how to contact him. I saw his last activity here in RFF was in 2011... If anyone has his contact, please let me know.
Roland.
I have several Jupiter-8 lenses, ranging from 50-70s, the only one that did not require re-shimming was a 70s black one. The ones didn't focus well on "Leica standard" bodies didn't even focus well on FSU bodies.
To OP: if gambling on eBay is something you don't want to do, maybe try to buy one from a member here?
I understand OP. Jupiter lenses have aluminium parts and very small, microscopic screws. Later, black, J-8 are easier to re-shim. But if you can't do it yourself and here is nobody left who will do it for money, does it have to be J-3, J-8? Where are LTM 50 1.4 Canons which are sold at the same price as J-3, were correctly made for Leica and regular service will take them for CLA.
First GOST to make it as official number 28,8 ±0,02 was in 1963.
https://www.zenitcamera.com/qa/qa-gost10332-63.html
On practice, before 1963, after and now it doesn't matter at all. It was all over from factories. This is why in the passport which was with every lens they had actual number. Same was for LTM FSU camera. With FSU LTM camera and FSU LTM lens purchased separately it was necessary to check and re-shim if needed.
But here is one more thing. I re-shimmed J-3 for M first. It was three extra shims. Later I took off two shims to make it for FED-2. After it I used it at M3 and M-E. It was not bad at all. :)
Wide open J-3 on M3 with two missing shims:
And another one, f2.8 or so:
Yeah... I used to have a Canon 50mm 1.4 but sold it because I didn't really like it very much, and it was very big and heavy. The reason I like the Jupiters is because they are Sonnar lenses, with Sonnar characteristics.
For the rest of my more "serious" photography, I have a Summicron v4 ;)
Thanks for the info on 50 1.4. I was considering it, but I'm not after big and heavy either. If you want it small it is hard to beat J-3 and J-8... Get J-3+, brass and 0.7m.
I don't know what the position is your side of the pond but here in the UK I'd check the lens on the M9 and then go to a repairer and ask them to adjust it as or if necessary. Any competent repairer ought to be able to do it.
Bitter experience tells me to check things first and not believe everything I read on the internet. Then get someone competent with the right equipment to sort it out. (We all sigh when camera shops close for good but seem to think it can't happen to repair shops, despite always recommending home made repairs and modifications: perhaps the DIY repirs keep them going.)
BTW, the old ex USSR cameras (Zorki) that I own made by KMZ say (in the instruction manuals) that the lenses have the standard registration for a screw thread Leica. I other wonder if people have read about them not working, tried to sort it out themselves then given up and sold the result to annoy someone else.
Regards, David
f/2 on Bessa-R
f/2.8-ish on Canon L2
The lens itself on Canon L2
To be honest I have yet to see a J-8 that focuses well on FSU M39 bodies but not well on "Leica Standard" bodies (or the other way around). My experience is that they usually work well or fail on both groups.
Testing the lens on M9 is a good idea. However if you don't know someone with a M9, you can simplely use ground glass or matte-finish tape + magnifier on your film RF to test the focus accuracy. See Calibration part.
I was trying ground glass for FED-2, Zorki and Leica camera, with macro lens on DSLR as most effective magnifier . Personally, it was not giving me confidence. I switched to taking pictures of focus scale target and scanning it to see what is better. One film with no factory shim, with factory shim and one, two, three extra shims. On the crop of the scan it is visible in millimeters. Ground glass, not so much....
Kostya,
Try using reversed 28mm or at least 35mm lenses to view ground screen. I have been using this method for quite a few lenses. Latest one is 6cm f/1.5 Sonnar in LTM, that came to me not properly assembled. After disassembly and reassembly I used one of SLRs with 105mm lens to check infinity, and reversed 28mm on ground glass to check close focus. It worked like a charm.
I bought a NOS Jupiter 8 from a Russian seller on ebay. I didn't want one with miles on it.
I am stunned by how good this lens is for $60 new! It focuses perfectly on LTM bodies, but not on M bodies. There it back focuses significantly. But the solution was easy, all I did was shoot it on my digital M, and see how much I would need to adjust focus by. This is even easier to do if you have an M with LiveView, you just compare where it focuses through the RF vs through the EVF. You don't even have to take a shot!
After that I have no reason to open up the lens, and potentially mess things up. Or pay someone more than the lens cost to mess it up for me!
Interestingly, the lens came with a spare shim in its hard case. I guess they know that it may need to be adjusted depending on what camera is to be used.
Thanks, Sam. Will do. I have I-22 which I re-shimmed for M, but it has to be taken apart again for optics cleaning. I'll try Color Skopar 35 for reversed view.
Interesting that it works with a screw thread body and not on an M, now I wonder if the adapter throws it out. It's odd, isn't it?
Regards, David
