Canon LTM Canon 100mm, f3.5---first impressions
sirius
2:38 AM
I just received a Canon 100mm f3.5. It's a really pretty lens and fun to use. The case has red velvet inside---ooOoh----and the lens cap is rimmed with black velvet so that it glides on really smoothly. I like how much you have to turn it to move the focusing. It allows for a lot of accuracy. I was wondering how well a tele lens would work on a rangefinder. These old Canon's are so nicely constructed!
The apperature ring is rather loose. I am used to the click stops on the 50/1.8. Is there a way to tighten this or is it normal for the lens? I'm not really sure that it bothers me. It's just different.
cheers
Yeah, they don't come much prettier than the 100/3.5. (Although the black/chrome Elmar 90/4 is pretty in it's own way.)
The aperture ring is normally loose and clickless. I think this is so that you have a chance of changing it without changing the focus of the lens, since it is a "rotating front" lens.
If you're using a II, III, or IV family camera, just set the VF at 1X, and you have a reasonably accurate frame. Of course, the later models all have explicit 100 framing options.
The 90 and 100mm lenses are indeed nice on a rangefinder, although they are even harder to use in "action" situations than the 50mm lenses.
