Canon 19/3.5 FL + Converter B in *bay
Hi Robert,
The finder is important here. It is the original Canon 19mm finder (which is rare) Some people buy the set just to get the Canon finder.
Looks exactly like what I have; The Canon FX original set and original FX finder (I have #11131). The Converter B is necessary to go to 39mm LTM. I use this lens fairly constantly, it is great to use. With a leica M adapter, it works great on everything but a Leica M5. And it won't mount into a Sony Nex.
So this is not the RF model ... it is for the FL mount. The Canon B opens up a whole new line of FL and FD lenses on LTM bodies. Thanks to Mark, I got from him a lens plus adapter.
He may also have recommended it to me. RIP Al.
I love using thsis classic lens. It allows me to skip 21mm-24mm lenses.
As the seller said, with converter B it can be fit to LTM body but not coupling, this makes me giving it up.
Hi Conrad,
Still enjoying your 25mm Finder. 😀
No need for rangefinder coupling, with such a wide lens. Even at F3.5 you can easily guesstimate focus, and depth-of-field is humungeous, so you are covered, if you overestimate and underestimate the distance.
The rangefinder coupled lens is usually 2X-3X the cost of the FL one.
Hi Conrad,
Good to hear that the 25 finder makes you happy with !
So I need to reconsider this 19FL again !
