Canon LTM Canon 50mm f/0.95 w/Bessa-R?
niimo
7:13 AM
I currently own a Bessa-R and I am considering picking up the Canon 50mm f/0.95. Does anybody know if the two are compatible? I did some searching but came up with nothing. I appreciate any info you can share.
thanks!
the .95 is made with a special mount (not screw mount) for the Canon 7 or 7S. It is commonly converted to Leica M mount for $ 300-400, or so, but I've never heard of a conversion to screw mount....it might be able to be done, but the Bessa R will not be able to focus it well enough anyway.... the lens really needs an M3 or other camera.
Dan
Dan
Ah I see. That clears that up, thank you very much Meleica. :)
payasam- I appreciate the confirmation. :)
Meleica- Oh that's your page! hahaa just went by there earlier, very informative. I have been considering the 1.2 and now that I know the 0.95 won't fit the Bessa-R, I may be inclined to go with that.
Everybody's right about the "won't fit" part -- an M mount just barely fits around the rear element of the 50/0.95, and a screw mount (which has a smaller diameter) would have to be thinned out so much that it wouldn't have enough strength to hold up the lens.
However, I'm not so sure about the "50/1.2 is sharper" part... see this thread (click.) (It's been suggested that the 50/1.2 I used for my comparison may have been off a bit in focus accuracy, and of course that's a possibility -- but then again, maybe not...)
jlw said:
However, I'm not so sure about the "50/1.2 is sharper" part..QUOTE]
one test and one lens sample doesnt make it so. I owned both lenses and used on film cameras and I was happier with the 1.2....but my use is also only one sample :)
Dan
PS - I wrote "probably sharper".....not "is sharper..."
venchka said:
Canon 7 bodies aren't too expensive.
This is true, although for the very nice ones, it seems like they can get a little pricey. The thing that bugs me is that I just purchased the Bess-R this past week. I suppose I could sell it if I really want to pick up the 50/0.95 with a good Canon 7. The one thing that bugged me about that camera was the lack of a shoe mount. Always a catch, right?
Thank you for that link! It's always good to see comparisons, whether the results are the standard or the exception--it does still say something, right? Thanks!
If you can find a decent 7s, you can also have your shoe available. A very nice shooter, with the long RF needed for a lens like the 0.95. They don't seem to go for much more than a nice 7, if you can find one without a lens. I've also seen them with the 1.2 for less than the body+lens prices.
A good 0.95 is a reasonably sharp lens, and will compete with the slower stuff when stopped down just a bit. But, really, the reason for using a lens this large and this heavy is to get that max aperture, isn't it?
If you do find a 7s, it will be priced less than an M3, and it's as good as the more expensive marque, AFAIK, and I own both...
Harry
Yes. But on the other hand, its good stopped-down performance means that you don't have to lug around (or even own) TWO 50mm lenses for low-light and normal-light work.
This lens seems to have sold well for an exotic ultra-speed optic, and I suspect that one reason was that it did a perfectly acceptable job at normal apertures, where most purchasers probably used it most of the time.
Harry
Mmm.. yes, indeed! thanks for pointing this out. 7s' seem to be much rarer then the 7, or even the 50/0.95 lens! Much less one that is working and in great condition.
So, I went for it. I picked up a 7 and the lens. Which means my new Bessa-R will likely be up for sale soon. hahaa ah well.
Thanks everybody for your sound and helpful advice!
