Canon 50mm f1.8 LTM on M6 - wrong framelines?
spkennedy3000
www.simonkennedy.net
12:37 PM
Hello,
Sorry if this is a really stupid question, but I just bought a Canon 50mm f1.8 to use on my M6, and it seems that the 28/90 framelines display on my .72 camera.
Is there a way to get the 50/70 framelines to display?
The LTM-M adaptor is a Voigtlander model.
Would very much appreciate some help in this matter.
Thanks,
Simon
Are you sure the adapter is the one for 50mm lenses? As you probably know there are different ones for the different combinations.
Ray
I had the 28/90 as well, I searched around here and found that you can file it down yourself to be a 50 75 and it works great! Be very careful doing it, only a little bit needs to come off and if you go too far it will make the problem worse.
