Canon 7s Repair Recommendations?
KoNickon
Nick Merritt
1:38 AM
I'd appreciate your recommendations for a repair and CLA. Mine has a shutter issue -- seems as though the wind lever mechanism has become detached from the shutter. You can wind the shutter by manually turning the wind sprocket, but that's obviously no good for actually using the camera.
The meter seems off by a stop or two.
But what seems almost the most vexing problem for me is that the RF patch seems out of focus -- almost as though I need a dioper adjustment to have a crisp image, but I'm not sure that's something that can be adjusted. Anyone else have this problem?
Essex Camera is a logical option for the work, but does anyone have other recommendations? Thanks.
Clarence Gass repaired my 7s
Clarence Gass repaired my Canon 7s.
It's finder is sharp, and I had him adjust the RF as well as the Canon 50 1.4 to be right on focus wide open. When I got it, the camera RF was way out.
The lens was focusing "beyond infinity". This can happen with the original Canon rear caps, as they are very shallow. If you try to focus the lens to infinity with the rear cap on, you can screw up the RF cam, which will hit it.
My shutter winding is smooth as butter, and the timing is accurate.
I don't believe that there are any potentiometers to adjust in the Canon 7s meter. However, I use the cris adapter with silver 1.5 cells, and the results are very accurate.
Gass Camera Repair
5604 Johnson Drive
Mission, KS 66202
Tel: 913-432-6057
Tuesday to Friday (closed Monday) 9 - 4:30 central time
Saturday 9- 12 Central.
Best to call and talk directly to Clarence first.
If there's any knock against the 7 or 7s rangefinder patch, it's the "mushiness" associated with it. It's not as sharp and well-defined as a Leica M. A good cleaning of the viewfinder can help things a little bit, but just be sure to use a repair tech who knows what he's doing.
As for other repair techs, you might try Youxin Ye, though I'm not sure of he services the Canon 7. I think DAG services the 7.
Jim B.
Incorrect readings of the 7 or 7S meter, if they are consistent across the range, are because of incorrect meshing of the gears driving the meter readout. I am always surprised at how very often people neglect to set this correctly when reassembling the camera.
Take off the shutter speed dial. This is a bit tricky. Completely remove the grub screw between 1 and 1/2, and then rotate the dial until the screwheads of the other two are visible through the holes in the dial. Note the shutter speed. The other two screws only need to be loosened.
Lift off the ASA/DIN dial.
Pick any usual ASA speed. Turn the brass gear appearing at the left side of the hole where the shutter dial was until you get a correct reading for that ASA speed and shutter speed on the meter.This is best done when you have a large deflection on the dial.
The trick is to reengage the gear at the bottom of the ASA/DIN speed dial with the gear driving the meter in the correct position so that your chosen ASA speed shows through the aperture in the shutter dial when it is placed back in its correct position. This is rather fiddly, but with a bit of patience, you will get everything right. Put the removed long grub screw back in and tighten it. Then rotate the dial until the other two can also be accessed.
Dez
Interesting, and thanks. The thing is, I think the High range (low light) is off, but the Low range (daylight) is more or less accurate. But I'll experiment some more.
Dez
Well, having one range correct and the other not is reasonably common with the Canon 7 which changes ranges by adding a resistor, but the 7S switches ranges by rotating a mask in front of the CdS cell. If the cell's response remains linear, then fixing one range should fix both. Does someone out there have some info on the aging characteristics of CdS cells?
Dez
Make sure the mask is coming into place correctly when the ranges are switched. You can see the mask by looking carefully into the cell while changing the switch. I have seen a case where this got disconnected, and it sounds like your camera has had a tough life. It's worth putting work into it though. The Canon 7S is a desirable camera.
Dez
The Canon 7 is an easy camera to work on. The winding issue might be caused by a piece of linkage combing loose, usually under the bottom cover of the camera. The viewfinder can become dim because there is an air gap between the lenses, you can clean between the gap if you remove the top cover. You can also clean the eye piece window, and a second eye piece window beneath the first one.
As for the meter, you must check that the shutter speed knob and meter gears are timed correctly. You do this by setting the ASA to 400, and then turning the shutter speed dial until it shows 1/15. With the meter off, the needle should indicate at the orange f/2.8. If something different shows, you will need to back out the three grub screws which hold on the shutter speed knob a few turns each (do not fully remove them, they are easily lost), and lift off the knob, you will see the brass gears beneath, turn the gear until the needle indicates the orange f/2.8, then reinstall the knob.
Thanks. So how to remove the rotary back release from the baseplate? Looks like I'd need a pin spanner to remove it from the film cavity -- but pretty darn hard to get at the holes.
Regarding the meter, when it's turned off, the needle is nowhere to be seen -- not anywhere near f2.8. This seems like the way it's supposed to be....
Check the 7s sensor unit. First there needs to be a clear pinhole in the moving cover for selecting high and low light sensitivity and behind the "mask" is the Cds sensor. The sensor may have "tinted lenses" on it for as far as I can tell calibration. And, I have found smoked or clouded sensors which after cleaning resulted in a perfectly calibrated operation. In one 7s I removed the "lens" which appeared to have oxidized. Careful replacing to ensure it stays in position. Initially working on the 7s I looked at pictures of operating cameras to locate the position of the gears to reflect the proper scale/ASA/speed position, out of desperation. It worked for me. When the meter does nothing when the switch is moved most likely there is a film on the contacts on each side of the meter under the camera top. Sand it clean and that may solve the most vexing problem, corrosion. I have noted the correct positioning of the scale, shutter speed asa setting for reassembly and now take pictures before disassembly. Best of luck.
According to the 7s manual for operation the Cds sensor can sense a Light Value of 2. Other than the Hi-Matic, I think 5, that level of sensitivity was not common afaik. On the 7s camera adjustment of the "3 screws" for 1/1000 sec. I have wondered whether this was intended to allow the 1/1000 curtain separation to operate more narrowly providing an effective higher shutter speed, which would allow use of higher speed films, consistent with the sensitivity of the meter...since I am not a repair nor design professional that is mere speculation. Imagine that!
Newbie here. Might as well revive this thread instead of starting a new one. I recently inherited my Dad's Canon 7sz with a 50mm f1.4 and "everready" case. It has been unused since the late 80's when my Dad moved to a Canon T50. As near as I can tell, the shutter curtains are wrinkle-free, and speeds all function, but the rangefinder patch seems dim to me and although the battery check does work (using a battery from my mom's hearing aid), the light meter does not appear to function.
Question:
Who repairs Canon rangefinders? Any recommendations? Seems like at least a CLA is in order. Most of the discussion about repair places appears to center on Leica equipment, which makes sense.
Thanks in advance
If you're in the U.S., DAG does (Donald Goldberg), but he probably has a months-long waiting list. KEH (the used camera folks) also work on rangefinders. Look at their website. If you're open to sending your 7s to Japan, Kanto Camera will do great job.
Jim B.
I've used Dag, Youxin, and sherry and Gus Lazzari. All of them are good. You can calll Gus and ask him what is backlog and commit to a time. Like all them, partly, mostly, clearly, quirky.
I've heard many good things about Precision Camera in Austin, Zacks Camera on the East Coast.
