Canon EX Auto top plate removal
mortenfyhn
2:04 PM
I found a Canon EX Auto recently, and the little transparent plastic bit for the frame counter window fell into the camera after some use. It should be easy to fix, but I can't get the top plate off. The part I'm stalling on is a lockring (I assume) in the film advance lever. Do any of you know how to get it off? It's the third piece you reach, after the outer bolt and a very thin black ring (both visible when the camera is fully assembled).
Just in case someone in the future has the same problem and ends up here: The lockring turned out to be opposite threaded, so it loosens clockwise.
