Canon LTM Canon L2 rangefinder
nukecoke
⚛Yashica
4:42 AM
photo 4 (1) by X. Yang, 於 Flickr
I won a "Canon VL2" on eBay, but it turned out to be a L2 with metal curtains. I was too careless to notice the self-timer and flash sync selector differences. I have no idea if the curtains were replaced after factory or made so as is.
After cleaning under the top plate, doing some shutter accuracy and focusing tests/calibrations... (you know, all the necessary things), I became a happy owner of this solid and practical camera. So I decided to write down my observation and thinking of this camera. Some of the points in this writing might have been post online by others while some might not.
Viewfinder/Rangefinder:
As one of the biggest features of Canon V and VI series rangefinder cameras (except Canon P), the viewfinder has three selectable modes/field of view: "50", "35" and "RF"(for critical focusing). You can turn a cogwheel - namely "Viewfinder Selector" - near the eyepiece to select the one you want manually.
The magnification of viewfinder is x0.72 for 50mm, x0.4 for 35mm and x1.4 for RF. The view of RF mode is oval-shaped, so you can't really use it as a 135mm FOV for framing as some online posts suggested.
Unlike Canon VI series cameras, none of the viewfinder modes on L2 have bright frame-line nor parallel correction. Talking about actual using of viewfinders, I actually prefer good "peephole" type to bright-line type with too many cuts/gaps in between, and I must say L2's "peephole" is really good. I'm an eye-glass wearer and prefer shooting with glasses on. The eye point of L2's viewfinder is long enough for me too see the whole frame, especially the 35mm, thanks to the low magnification. I don't mind soft edges of the frame and I will definitely use this camera more due to the nice viewfinder. Currently it has the best peephole type viewfinder I've used. The next to best I've seen is the one on Zorki-6.
And, don't worry about scratching your eye-glass with the viewfinder selector cogwheel, which you might have read somewhere online: the viewfinder eyepiece protrudes a bit, so your glasses are very unlikely to touch the cogwheel.
The brightness, or maybe calling it darkness makes more sense, of the viewfinder is not bad at all, only around -2.5EV at 50mm mode, similar to Zorki-4 and 6, a bit worse than the bright and more advanced Canon 7 (-1.5EV), better than FED-2 (-4EV) and KIEV(-3.5EV). I'd say It's good enough for casual indoor shooting.
The rangefinder patch has a round shape with a gold tone. The visibility of the patch is not impressive (I'd call the one on Kiev-4 impressive, but maybe it's partially due to the darker viewfinder), fortunately the size of the patch is big, so it's still fairly easy to focus. Canon's online camera museum says the gold mirror was changed into silver in the Canon VI series in order to increase patch visibility , however I can't compare since I don't own any VI series cameras.
Shutter:
The shutter works well when it arrives, which corresponds to the praise from online folklore. I have no idea when was this camera last serviced or used for actual shooting, but judging from the happy fungus clusters inside the viewfinder I dare say a couple of decades. The shutter was really built to last and relatively maintenance-free, as Canon's manual "bragged". I like the metal shutter curtains since it's safer, and it's one of the reasons why I bought this camera.
The shutter sound is noisier than most of the LTM cameras I own, namely my Zorki-4, 6, FED-2, and its grandson Canon-7, and on a par with my Zorki-1. All those cameras were home-adjusted and some of them have minimum shutter tension. Test shots turned out fine with no uneven exposure, so I just didn't bother to change anything.
Flash sync:
The L2 has FP(Focal Plane Bulb) sync only.
Lens compatibility:
For LTM cameras, I use FSU lenses only (call me cheap). I did the ground glass/tape test and it showed that my Jupiter-3, which focuses well on my Zorkis, focused well on the Canon L2 too, and then the test shots double-secured it. I calibrated the J-3 to have spot on focus at f/2 on my Zorki-6, and it behaves the same when mounted on the L2. My un-calibrated-for-nothing black Jupiter-8 also focuses well at f/2, at min distance. You know, the "non-Leica standard" thingy haunted me a lot when I was a complete newbie.
Another good news is my 1970s black Jupiter-12 mounts well on L2 and can be used normally without problem. With the J-3 and J-12 working, I'm good to go. I would occasionally use the J-8 and a rigid glossy black finish Industar-50 (when contrast matters) on the L2. Or someday I might buy some Canon lenses for it.
Size/Form factor:
The dimension is 140x75x31mm, w/o protruding parts. Not too small, not too large, though I won't carry out any attempts to use it as a pocket-able camera. One big plus is it stays streamlined with 35mm lens mounted, thanks to the smart design of multi-fov viewfinder.
Other things:
A small surprise to me was the frame counter COUNTS DOWN from 36 to 0 on the L2. After reading the manual I knew it's designed to be like this.
There is a film transport indicator on the top plate (as on all Canon V, VI and 7 series cameras), so when rewinding I don't need to stick the camera to my ear to hear the "pop" of film leader jumping out of take-up spool (I'm too cheap to buy a film leader retriever). A very handy feature for home film developing.
The camera hangs awkwardly when using both strap lugs. So I screw on another strap eyelet to the tripod socket and skip the lug on the left side of the camera.
That's most of it. With one test roll burnt, I've already started to like the camera. Function-wise, the L2 is equipped with all I need. It has what I missed when shooting with Canon-7, the elegance from a refined body, which was dropped for the sake of the projected frame-lines and the light meter.
I picked some not so boring shots from the test roll to post there, and skipped all the "focused on a bottle cap at 1m" pictures. All were shot on Fujicolor C200 and developed in Tetenal C41. Thanks for reading!
Jupiter-8
Scan-160630-0006
Jupiter-3
Pink Lighnting by X. Yang, 於 Flickr
Jupiter-12
Tomato Man by X. Yang, 於 Flickr
Jupiter-3
Rainy Day by X. Yang, 於 Flickr
Jupiter-12
Jupiter-12
Bench by X. Yang, 於 Flickr
Jupiter-12
Retired Holmes by X. Yang, 於 Flickr
Welcome to the wonderful world of Canon LTM! I have the VL (metal curtains, self-timer, and 1/1000th top speed). This has become my favorite all time camera. After messing around with Leicas I always come back to it. IMHO the shutter is more reliable than any Leica of the same era. (Others may disagree!)
My VL came with a capping 1/1000th speed and a very rough advance stroke. Since I'd worked on IIIfs, I decided to take the plunge and open it up. A good flush cleaning and judicious application of some oil and it now has the most buttery smooth advance of any camera I've ever had my hands on--including an M3 serviced by a professional. It is still smooth as silk and I haven't had the need to adjust the shutter for over 3 years since the initial CLA.
Like you, I find I prefer the non-brightline finder over the later Canon P (or 7). Also it seems when Canon 'upgraded' to the single shutter speed dial, the advance mechanism became more complex (or cheapened) and hence never feels quite so buttery-perfect on those later models. Also since I do a lot of double-exposures, the VL, L1, L2, L3 are a no-brainer. I know it is possible to accurately make double exposures on a P or 7 by winding back the film 1 1/2 frames...but what a pain...and plus you lose your frame count.
At some point in the L/V series they changed the viewfinder from green tone with gold patch to neutral with yellowish patch. Either type is great. If I hadn't also owned an L1 with cloth curtains, I probably wouldn't have known the difference. I think the earlier finder is slightly dimmer which may make the patch a little easier to see. (Selling that L1 is a big regret!)
I find the shutter is indeed louder than a Leica M--when the lens is off, or the back open...but in actual use the difference is barely discernible.
The strap lugs drove me crazy too. I posted my solution in another thread some time ago: https://www.rangefinderforum.com/forums/showthread.php?t=145014
Since then I've turned the brass piece downward which eliminates the sharp edges sticking up.
I no longer have the Skopar 50mm (nice lens but too modern for my tastes.) The Nikkor 5cm/1.4 is my go-to lens and the weight/balance is just perfect for the VL. I also use an Elmar red-scale, Summitar and a Nikkor 3.5cm/f2.5. Go figure--I can't stand Canon ltm lenses--I guess every camera company has their strengths and weaknesses...
Canon L-2
Canon L-2
Ah, the wonders of Ebay; especially during an evening after having had a few drinks :eek:.
Anyway, after a few days of nervous expectation I received, this morning, a beautiful L-2 body in full working condition: good rangefinder/viewfinder, shutter speeds all good, only slight wear to body, etc.
My questions are: - Aside from the 1/500th second difference of the L-2, to the 1/1000th second of the L-1, are there any other differences in the shutter?
- There seem to be few, if any, references to the L-2 in this blog. Is this due to scarcity, lack of collectability, or some other reason?
Thanks in advance,
David
There was an involved discussion of this range of Canons about a month ago here
The gist is that there are many variations of the L1/L2/VL/VL2 that don't always correspond to the 'official' list of features for each model. Having worked on a number of these, I can say with some certainty there is no difference in shutter mechanism between the models. Just the curtain material, and of course, the lack of a detent for 1/1000th on some models.
This line of cameras are my favorite RFs hands down, even more useful to me than an M4, M2 etc. I currently shoot with a VL and an oddball L2/L1 hybrid.
Nothing beats them for smoothness, convenience, ergonomics, and reliability. If you can find one of the brightline finders (the black style that couple to the pin in the hot shoe) you will even have framing accuracy as good as a Leica M. Enjoy!
L2 does too. Canon changed to metal curtains on lever wind cameras with the VL series.
Jim B.
Thanks Jim - not sure where I got the idea the L2 had a St. Steel one like the later versions of the L1 (according to the Canon Museum)
I was getting a haircut a few weeks ago and because I was early I popped into the charity book shop next door. I came across a copy of Dechert's Canon Rangefinder book for £2.
A week later I had an L2 !! It is such a fine camera, I think I like it more than my Leica M2. Mainly because I can see the whole 35mm frame with my glasses on. I've had a Canon 35/2 ltm type one for some time and promptly added this to the L2. Perfect combination with the Lime One light meter in the accessory shoe.
Purchased an L2 from forum member Al about a month ago, and am really enjoying it. Took a bit to get used to a few things, but been shooting it pretty exclusively for the last month. Fitted with a Canon 35mm f1.8 from the same era, and occasionally swapping to a Nikkor-SC 5cm f1.4, it seems to meet most of my "walking around" needs.
I might remove the top plate (if I can find a service manual or instructions, as I've never worked on a Canon RF) as the viewfinder is pretty fogged, but otherwise, it's a joy to shoot.
Best,
-Tim
PS: I do have a question for you folks who also have an L2, does the front of your viewfinder look like this? Mine does. It seems like there was once a coating over the viewfinder front glass and now it's a bit foggy and scratched off.
Would love to hear your experience.
.....I do have a question for you folks who also have an L2, does the front of your viewfinder look like this? Mine does. It seems like there was once a coating over the viewfinder front glass and now it's a bit foggy and scratched off.......
I didn't see any sort of attachment, but the viewfinder of my L1 has a very sight "mottled" appearance. No effect on viewfinder brightness or contrast, best I can tell.
Jim B.
Jim B.
Hi Jim, You can't see the image of the viewfinder glass I posted in my "PS:" ? Weird, it shows up on my browser.
The picture shows what looks like a blue-ish coating on the front glass of the viewfinder and it's covered in fine scratches, and is cloudy around the edges.
Best,
-Tim
Best,
-Tim
No, no image visible in your PS.
And your viewfinder sounds like mine, a blueish tint. Mine has a slight mottling that I can't see through the viewfinder.
This thread has inspired me to use my L1 today. I'm photographing a holiday "mask making" class at our local Arts Center. Using my cellphone for color, my L1 and Tri-X for B&W.
Jim B.
That's a mystery Jim, Oh well.
Happy shooting today. I was running around downtown Chicago yesterday and had the L2 with me. Again, fun camera to shoot. Went thru almost an entire roll of Tri-X. Stopped by Central Camera (in their new, post-riot, temporary location) and showed them the L2, most of the employees had never seen one before and thought it was pretty cool.
Best,
-Tim
The viewfinder of my L2 is clear with a slightly warm tint . Very clearly defined patch. I don’t see any mottling. When it was recently serviced a few strands of fungus noted out of reach with the 50mm prism. I can’t see this and it hasn’t affected use. Perhaps I’m lucky that my finder is in pretty good condition.
As I understand it from the Dechert book these finders have lasted better than the likes of the VI or P. He of was of course writing over thirty years ago.
I tried to upload the pictures again, hope it's visible now. That's exactly what the front glass on my viewfinder looks like.
Best,
-Tim
