kb244
So I'm trying to find a PDF or scan of the Canon P manual. I've already done the usual search of finding the free manuals online much like I did for my EOS-1, or my Canon FTb, and so forth.
Also a flash related question.
I know that to use a electronic flash on the Canon P, you set the shutter to "X" which I think is approximatly 1/30th of a second, etc.
But when using the Flash Unit V, using bulb flashes such as the M5, M3/2 etc what shutter speed should be used? On the back of the sylvania bulb boxes, theres distance and apertures for 1/30th and slower (ie: "Adjustable camerat @ 1/30th"). then further down it has guide numbers for adjustable cameras, with shutter speeds for "M Sync only" from 1/30th to 1/500 (another list for FP Sync Only). , then a row of numbers for "X" or "M" Sync upto 1/30th. Can I use a higher shutter on the P with a bulb flash if the box allows for it, or do I have to stick to 1/30th and lower. I know on the Argus C3 with the flash gun, it has to be 1/25th or lower or it will not show up, but I think maybe the Canon P might differ.
One of the reasons I wanted the manual to see what Canon recomended, just as with the Argus C3 manual, says 1/25 always.
