Canon RF body cap.
Pyrs
6:45 PM
Can anyone help me with an answer to the following?
Do Canon RF body caps clip fit onto the outside of the body flange or do they screw into the throat?
What type of body cap fits onto the Canon 7?
Many thanks.
Pyrs.
All the Canon body caps I have ever seen have been screw-in types. Earlier ones were metal, later ones black plastic
Thanks for your reply.
I have a metal cap marked 'CANON Japan' approx 47mm internal diameter with a shallow lip which will clip fit onto the outside of the flange of a Canon L1.
Any idea what this was intended for?
Best regards,
Pyrs.
Dunno. The longer lenses, 135/3.5, have 48mm filter threads and 50mm O.D. Maybe for one of them? My 135/3.5 has a metal Canon slip fit cap.
Best regards,
Pyrs.
Canon made caps that fit on the hoods, to reverse them. Nikon made similar hood/cap combos. One of the sizes was 48mm, so I wondered...
The cap has the large Canon logo, and has screw threads on the inside of the "lip". I can put up a quick photo if that would help my lousy explanation.
Harry
Is this like your cap??
The cap is at the left of the photo. It may fit on the flange, but you are probably ruining the threads on the inner rim of the cap. These were made in 3 sizes, and are scarce to rare, depending on size. The exist, as I recall, in 34mm, 40mm and 48mm sizes.
Harry
Hello Harry,
Many thanks for the information and photo, you appear to have the answer.
My cap appears similar to yours, the word 'Canon' is in lower case and of a bigger print size than the word 'Japan' below it. It measures as follows, O.D. 49.1mm, I.D. 47mm, Depth 4.8mm.
The screw consists of 2 threads only, probably of 48mm size and the inside front is painted matt black with no sign of padding. The outer lip is also knurled.
My Canon black 135 3.5 has a filter size of 48mm, so this cap may have been made for the hood of a 135 3.5 Serener or Canon chrome lens.
Thanks again and best regards,
Pyrs.
Being scarse I better not use it as a body cap!!!
Harry,
Looking at your photo again, my cap has no brim and I have no cylindrical hood. Is the brim on the hood?
Pyrs.
No, there is no rim on the cap... the "rim" is just the base of the hood itself.
As I mentioned, this type of cap was also used on the Nikon RF hoods. They make a nice compact unit, and protect the threads of the hood. I use one on a Nikon 135/3.5, with a Leica/Canon mount, and it looks and works very nice.
I have examples of the 34 and 48mm caps, but haven't been lucky enough to find one of the 40mm, as yet.
The body caps can be found in metal, with Canon and Japan in 2 lines at the rim, and in plastic/bakelite (?) in black, plain front, with Canon and Japan in 2 lines, centered as the hood caps, on the inside. I imagine there are variations produced over the years, as there are for so many of the small Canon collector items. Makes life interesting......
I've included photos to show the items clearer. First shows inside of plastic cap and outside of metal one, with hood cap below. Second pic shows the other sides of the items. Note the flat black painted interior of both the metal caps.
The metal body caps are also rather tough to find, and you seldom see them on the auctions. For pure protection, go with the unmarked metal body caps sold by a couple of different vendors on eBay. Check prices, as they seem to be the same items, but price can vary by several $$. You can also buy a nice hood or two to reduce the shipping cost per item. There are some nice ventilated hoods that work well and are priced to sell. No relationship with vendors, except as a satisfied customer.
Harry
Harry
