Canon LTM Canon Serenar 35mm f3.5 pretty good!
Darinwc
7:11 PM
I picked up this little 35mm Canon Serenar for a good price. It needed a cleaning and a lube. It is now working great even though there is still a bit of haze I could not remove.
It flares quite a bit, but that could be partially due to the haze left on it.
In the daylight, I mostly shoot at f16 or f5.6 in the shade. So no need for wide open performance.
It is a 4 element Tessar wide angle design like the elmar. But it is in a fixed non of-collapsible mount.
I am generally happy with this lens. Results are sharp and pleasing. The results can be interesting in some situations.
I underdeveloped the film a bit, so the negatives are a little flat. But they scanned easily enough.
No, I just remove all the upper and inner lens elements and clean them. Before reassembly I clean the middle element that is still mounted. I have it down to 10 minutes. You might have to get a tool to remove the rings at first, then I just snug them and use a toothpick to remove and replace.
No gear grease needed>
I also had this lens (Canon Serenar 35mm/3.5) and use it with my Leica M mount via a simple adapter L39 - M. The images produced by this lens seem to be quite OK with me. I insert some pictures for your reference. Thank you.2024-06-24 17-56-11_1245.jpg2024-06-24 17-56-31_1247.jpg2024-06-24 17-57-13_1252.jpg
