Centre spot filter on 45mm for street photos?
ian paterson
1:17 PM
Hi - after many years of using my Xpan only for landscapes with Velvia, I'm loading it with XP2 and heading out into the streets for a change. Should I leave the 45mm centre spot ND filter on the lens or can I get away without it for street work?
Thanks,
Ian.
I say you were better placed to judge that since you have the camera, lens and filter and have used them. what do you think?
I don't bother with the center filter with the 45mm lens, even with Velvia. I use a center spot filter only with the 30mm lens. The 45mm lens on the XPAN is the same in horizontal coverage as a 25mm lens on 24 x 36 format. I don't find the edge falloff that significant. If you do, another idea might be to use a lower contrast film, for street work. It might be more forgiving of the random light variations in that kind of shooting, as well as minimizing falloff.
Thanks guys - I use the filter for landscapes since there's often large areas of same colour/tone (eg sky) and thought the fall off would be more obvious than with B + W street shots. I'll go without to reduce the amount of glass in front of lens.
ian.
