Usually I dye leather just to restore the original color sans scuffs and abrasions. But, to change the color would be similar in principle. You may have to dye it several times.
First use acetone to remove the original glaze/wax and some of the original finish.
Second, dye the leather using leather dye. I use Fiebing's dye. It is better to use several lighter applications and be even and thorough (i.e. no missed spots), rather than to try to achieve your final color in one go. Let dry 24 hours before proceeding.
Once the color is suitable to your taste, then moisturize the leather, and seal it. I usually use Leather Honey liberally, and let it soak in 24 hours. If you want it to really soak in, use a hair dryer to warm the leather. After 24 hours, wipe off the excess. At this point, if the case had some sort of glossy finish, I use Fiebing's Acrylic Resolene to provide some water resistance. Some neutral cream rubbed in liberally will give you a very beautiful finish.
I personally hate raw leather edges, so I always use some Fiebing's Edge-Kote to provide a nice black leather edge that will not fray.
I've restored many a case this way, including a really beat up Aires III case. A few Nippon Kogaku cases for my Nikon F, F2. And, more for Leicas, Agfa Super Isolette, etc.
Although cases are worth the effort, I usually cut out and discard the old leather straps. They are going to break on you without any warning. Sometimes you have to rivet the strap to the case itself, for cameras that don't have eyelets for the strap (e.g. Agfa Super Isolette).
Doing all this properly takes up the better part of a week.
Use gloves for all of this messy work.
