dogbunny
Registered Boozer
So I ran across a temperature compensation chart on the Ilford website and I used it for developing a couple of rolls this weekend. Overall, they look good, though I haven't scanned them yet.
I was curious if there was anything to look out for / be careful with when using this method. This method appeals to me because it's only the beginning of May and already the water comes out of the tap at around 26 degrees and even with the AC on the room temp of the chemicals is about 25 degrees.
I've been measuring out all of my chemicals, then just putting them in the fridge for 10 minutes or so and that gets them down to about 22 or 23 degrees, then developing from there. The development times are shorter, so the only thing that I can think of being different--besides the time/temp--is that the total amount of agitation would be less...so maybe it would result in less contrast? Just guessing. I'm using D76, filtered water stop bath, and Ilford rapid fixer.
Any words from the more experienced are welcome 😉
DB
DB
