Changing Lens
bwidjaja
Warung Photo
4:06 AM
Hi Everyone,
As much as I like having a camera with the ability to put different lens on it for flexibility, I somehow find it cumbersome to change lens while walking around and shooting with no particular objective. I somehow feel that the fact that i need to carry around an extra lens, worrying it not being damaged, time taken to change (and maybe change back later) too tedious.
Does anybody feel the same way? Any suggestions?
Berhen
For a while, I was going out with two fixed lens rangefinders (before I'd shot them enough to trust either camera) or one and a TLR/folder. Nit much lens variation, buri found that pretty easy.
These days I often take a ltm camera with a 35 and 50. Even more of a hassle as I take the finder in and off when I switch lenses. Maybe I'll leave it on now that I'm using a variable finder.
Two years ago Sherry K. upgraded the finder on my M6 .85 and it became a wonderful camera. I carry it with a 50mm on it and my early M6 .72 with a 35 on it. Turns out to be a great combination. Joe
For lazy, Rollei 35 with tessar 40 mm.
For SUPER lazy, Nikon D40 + 18/135. Maybe some day I will get a 35 1.8 for it.
Neither of these happens frequently.
Well if you've got the wherewithal and your using an M mount body you could try to find one of the Tri-Elmar lenses.
If I had the extra scratch laying around and if I could find one I'd like to give the 28-35-50 one a go. I've no idea on the performance of either of them but it would be nice for a one body one lens outing.
I'm thinking of getting an M3 so I can avoid changing lenses so frequently. I'll use my 50 'lux on the M3 and keep the 35 'cron on the M4.
In the meantime, lens changes are much easier and less likely to result in dropping a lens, if you follow a routine.
When I need to change lenses, with the camera hanging from its strap, I'll take the lens I want on the camera and set it against the lens on the camera, with the lens caps on both lenses and front to front, while holding the two lenses with my left hand. I proceed to unmount the lens from the camera, switch the lens rear cap from one lens to the other with my right hand, turn my left hand and mount the new lens on the camera. All the while, I have a firm grasp on both lenses and don't have to put anything down where I can lose it. It works very well.
I'm not a pro, so I don't need insurance. Plus, I don't own another M body.
So if I need to change lenses: I change the lens. Voila!
(I will tell myself to really, REALLY slow down - once put a lens on the pavement from about waist-high, never want to hear that sound again).
On those days when I can't be bothered, the second lens stays in the bag, or even at home.
Yaers and years of practice I thought I could juggle most photographic kit, changing lenses no problem, until I got a Contax G, for some reason still cathces me out a bit and the odd FSU lens can be a bit of a bugger. I normallly take two cameras out fitted with a 35mm and 50mm lens, I just swap between the cameras
It might get cumbersome at first, but go slow and be deliberate. You'll find it's not such a hassle after all. Just, yeah, be careful not to let the lens have a concrete kiss.
Being an LTM shooter, and usually carrying 35-50-90-135 in my kit bag, plus hoods, I have changed lenses in the field... it's fiddly.
I've gotten better at it, but it's still fiddly...
Usually I just leave the 35mm on the body and shoot that.
If changing lenses really bugs you, then probably best to opt for a film SLR with a zoom-lens, or a P&S 35mm with a zoom.... or digital w/ zoom.
OR, head out with a fixed-lens camera, like a Retina I or II, or just your RF body and a "standard" 50mm lens, and learn how to work with that alone.
I find that carrying a spare rear lens cap facilitates the changing of lenses enormously. Remove the lens that is on the camera (it is capped at this stage) and place the lens cap on the lens. Put the lens in the bag and take out the second lens remove the cap, putting the rear cap in the bag and put the second lens on. I find that it is faster than loading film.
When I'm shooting with my Nikon SLR's and DSLR I don't even think about it, I change the lenses if I need to. I agree with the one comment above, and that is that a spare rear lens cap helps.
With my M6 TTL, I'm thinking seriously about picking up a 2nd body.
I've been on digital four years now (cue gasps of horror from the film fanatics). I use a 5D and I change lenses as and when I need to. I blow-clean my sensor, what, every three to six months? The dust problem is overstated most of the time. As long as you use a bit of common sense, you won't be getting a mucked up sensor all that fast.
Is the 5D self-cleaning? When I was using a D70 dirt was a problem, with the D300 and the self-cleaning set to run each time the camera is powered up, I've not had any real problem.
No, the 5D isn't, and what's more it's got a huge sensor. As long as you're not changing lenses where dust is swirling around or it's real windy, you should be okay. Also try to face the lens mount downwards when you're doing so.
