Changing shutter speed on FED 3a
w3rk5
12:59 PM
I just got a FED 3a from AlexPhoto off *bay. I have a question regarding changing the shutter speed.
Going counter clockwise, does it go like this? 1/30, B, 1/500, 1/250, 1/125, 1/60, 1/15, 1/8, 1/4, 1
Also, when I try to change the shutter speed from 500 to 1/15 (for example) it feels like it doesn't want to past 1/60. Anyone have any ideas? Thanks.
It may be that you're working against the resistance of the slow speed mechanism which "sets" as you adjust the speeds downward. The increased tension may feel to you as if it doesn't want to go. You should hear the gears turning as you take it to the slow speeds. My Zorki-4 works in just this manner and I'll bet your Fed3 does too.
Walker
Thanks for the replies everyone. They helped alot. I think it needs a CLA. When I use the slow speeds 1/15 or slower the shutter gets stuck. :(
I would say that the grease is going/gone sticky on the timer mech. It certainly sounds as though it needs attention.
Kim
It's fixed! :D I removed the top of the camera and noticed some moving parts were bone dry. I just added a little oil to those parts and voila.....it's fixed :D Thanks for everyones help. :D
