Cleaning a 90mm elmar
fredus
2:19 AM
Hi there,
I just bought a cheap elmar in order for me to learn a few things about lens cleaning ... Could you recommend some web link or books to get started ?
Thanks for your help !
Fred
Fred, we have a polymer called Opticlean over here. By all accounts it does an amazing job. Brush on, leave for up to 5 mins, peel off the cured polymer and presto! clean lens. Or so they say. Not tried it myself, though.
Ray
I've used Opticlean for a 6 months or so and it does an amazing job. Every lens has never being cleaner, good for storage too leaving the polymer on the glass. Watch out for the liquid running under the edge of the lens though and use a cocktail stick to remove if necessary. Try http://www.opticlean.com/ I'm not connected just enthusiastic about this stuff, makes life much easier.
Buy some good spanners, they are worth the expense after the 2nd lens you open up. I was very appreciative to receive both the blade type and pin type from SKGrimes for Christmas and they've been enormously helpful.
I would also advise drawing out or photographing each step of the repair as you do it. If you can look up the specific item you are repairing, there may be notes on disassembly and possibly a Youtube video.
Other tools/supplies I can recommend: Ronsonol or Naphtha for element cleaning and general grease cleanup. Grease that doesn't break down in heat, Tri-flow as a light lubricant/drop some on stubborn screws to help break them loose, Simichrome polish (if the coatings are damaged/hazy or you want a full polished look on aluminum surfaces, also works as a paint polish and cleans chrome bodies like Pentax or Leica cameras without changing the surface texture.
Oh, and #1 supply tip: Buy stock in q-tips, then buy in bulk.
Filing down screwdrivers to fit correctly or creating your own tools is part of it as well.
I just did a 90/4 Elmar for a friend, no big surprises and it cleaned up rather well. Still gets beat by the 100/3.5 Canon as far as image quality but that's not a surprise either.
