Cleaning Gear
Larky
11:29 PM
Hi all.
Cleaning gear, cloths, fluids, air blowers. What do you all use, and why?
I've tried many a cloth, compressed and non-compressed air, never used any fluids though. I am yet to find a cloth that does a really good job on the lens, they smear or create static and it's get's dustier than it was.
So, what do you all use?
A.
ROR Mist & Pentax cleaning cloth. Once the lens is clean a filter is placed over it. I have not had problems cleaning the filters.
Get a fluid made for cleaning coated optics and use it with a microfiber cloth. But first, use a brush to get the dust off. You need to use fluid since it loosens the grime -- you don't want to cause cleaning marks by bearing down too hard with a dry cloth.
brush , air, microfibre cloth and ether!
Done! Oh and some klenex (the soft one) sometimes as well!
Brush, or bunched up dry tissue to brush dust off.
Then,
ROR, Kodak lens fluid (lasts forever...), on a Kodak lens tissue, PEC pad, or Kimwipe.
Never really liked microfiber, or reusing something more than once after it's picked up any gunk off the surface of a lens.
I clean the bodies with a small flat watercolor brush, and have a goats hair 'mop' brush for dusty lenses. In the field I use a microfiber cloth. I like the Leica branded ones as they are white and easiest to see the dirty spots on.
Zeiss makes a wet wipe in a packet that is very nice for salt spray.
I'd like to find a US source for that miracle fluid cleaner that you paint on the lens and then peel off.
