whitecat
Lone Range(find)er
I have a Zeiss Ikonta which is in great shape except for dirt in the interior of the case. Any ideas to clean this fine velvet covering?
Thanks
Thanks
radiocemetery
I use a real soft and worn out tooth brush to loosen the debris, then a vacuum with computer cleaning attachments to pick it up. Works pretty good for me.
Steve
Steve
Tuolumne
You can use a suede brush, available at most shoe stores.
/T
/T
FallisPhoto
Thanks
I'll second the toothbrush and vacuum suggestion. If there is something you need a solvent for in there, then use Resolve brand fabric cleaner, but don't let it sit very long or get very wet -- or it may dissolve the glue. Even then only use it if the fabric is in good shape, or your velvet may go "bald."
