Closest equivalent to an Ektar 400?
Ste_S
12:13 AM
Ektar 100 is one of my favourite film stocks. It's fine grained and it's contrast and colour saturation work well in the UK when light is often grey and flat.
What doesn't work so well is it's speed. 100ISO today is f5.6 at 1/60 for example.
So, what would be the closest equivalent to an Ektar 400? Portra 400 and adjust in post? (I'll be working with scans). Ultramax 400 and live with the extra grain?
I once did a comparison of the colours from the two in relatively soft light. One was taken with the Planar on the Rolleiflex, the other in 35mm with the Zeiss Biogon C 35mm, a lens renowned for colour. I think it's pretty obvious which is which, but I did do a fair amount of saturating the colours in the Portra 400, whereas the Ektar was left untouched.
No idea if there is a current-day equivalent, but there used to be Kodak Hawkeye traffic surveillance film available that was nick-named "High Speed Ektar".
For saturated colours I'd also think seriously about the Lomography 800 shot at 400. It's a super film (almost certainly Kodak), and it's so much nicer (to my tastes) than the consumer Kodak films. With a small amount of playing it saturates very naturally, and is relatively fine grain, but I've never done the comparison with Ektar. There is also Lomography 400 but I have never got results I liked.
I’m currently part way through a roll of Ektar that I’m pushing at 400. I have seen some pleasing results from others which caused me to experiment.
This would be my ideal film but have tried a few and never got anything that was the same. I switch from portra 400 in the darker times to ektar in the summer. Can always add a bit of contrast in post.
Pushed Portra 160 (when overexposed), has a lot of contrast/saturation and is almost grainless.
Overexposing colour film loses contrast and saturation in every case I have seen.
It's why wedding photogs like to overexpose their shots for that pastel look.
Agreed. I use Lomo 800 @ 400 for a specific project I am working on where I need the intense colour.
I stocked up on Lomo 800 when it was available.
A few years ago I accidentally exposed a roll of Ektar at iso 640, which I didn't realize until after having it developed normally. I was surprised how well it came out. It has a look that probably doesn't suit everyone, but Ektar handles underexposure quite well, and while I have never really tried push processing, I would think that shooting Ektar at 400 and pushing the developing would work quite well.
Here's one from the roll I shot at 640,
Untitled by Colton Allen, on Flickr​
Pushing increases contrast, and slight overexposure will get you more shadow detail (and less grain like Ektar).
But I know what you mean, since my job is scanning film in a lab, mostly for wedding photogs. A lot of overexposure will result in a flat scan with pastel colors.
Many thanks everyone for all the responses
@CharlesDAMorgan Thanks for the comparison images, that's pretty much my experience when comparing Portra and Extar, even after some work in post.
Also thanks for the Lomo 800 suggestion. I like Lomo 800, and it's the only colour film I shoot in winter. I don't find it to be similar to Ektar though, even when over exposed. It's probably more similar to Colorplus (I suspect the Lomo stuff and Colorplus are all Kodacolor VR)
Thanks @swift1 and @faintandfuzzy for the suggestion to push/underexpose Ektar. I've not had much luck with underexposing Ektar so far. Whilst the shadows don't go muddy like some consumer films do, they certainly block out.
My local lab used to offer push processing for C41 until it's dip and dunk machine broke. I'll certainly give that a try when they've sorted that.
In the meantime I've ordered a few rolls of Ultramax to remind myself of what that's like. I've run it through Mamiya glass in the past and the tones have been quite smooth. I'll try it through Nikon glass this time which normally has much harsher contrast.
Nice photo.
Is this beside the HMS Victory in Portsmouth?
Sent from my iPhone using Tapatalk
Thanks - yes it's HMS M33 at the Portsmouth Historic Dockyard, right by Victory. It was a nice breezy day with the right blend of blue sky and fluffy clouds, so everything was photogenic!
