bwcolor
I'm trying to use batch processing in Aperture 3. I select a number of images and then call up Effex Pro. I then change to the filter that I want, which it nicely applies to the first image, but then applies the default filter that it depicted when the program was first called, So, I was trying to soften the color, but ended up with one properly processed image and a bunch of B&W converted images. I've been searching, but haven't found an answer... Thanks in advance.
I should mention that I'm aware of using 'next' and resetting each photo one by one.
Turtle
I dont think you can batch process at all and its a slow program at the best of times
