Color of processed XP2 Super
mrdoser
8:50 PM
Hi!
What is the color of a processed XP2 Super negative? I just had two rolls processed at my local Hema-store (chain of stores in the netherlands comparable to Wallmart I guess). The negatives came out kind of silver, blue-ish looking. Could it be that it was not developed in C41? Most prints look too black and white, not much in between if you know what I mean. Sorry I have no film scanner yet so I could show you this, but maybe you can tell from the color I described what may have happened.
Thanks
I've seen the same thing with my XP2 processed film. From what I've read, sometimes it's just the printing process that results in the colour tinge, and the negative is fine.
Here an example of XP2 processed by a spector lab as C41. The colour cast in the negative is minimal and the final result shows more than just B/W.
Did your lab processed the film as C41?
Developping XP2 as B/W film gives horrible results :bang:
Groetjes
Wim
I suspect it depends on the processing lab. I have both purple and "neutral" XP2 processed negatives. I suspect that the purple tint is supposed to go away if you don't skimp on chemicals while developing. Only time will tell.
It's a plum colour which any half decent lab can correct for in the printing.
Think of it like a twenty first century sepia otherwise.
