Contax G1 vs G2 for 21mm
Peter_S
Peter_S
5:28 AM
Hi!
I used the Contax G2 for quite a while, before switching to the M system. Well, besides the 45mm I truly miss the 21mm...nothing quite like it, and with the external VF I actually liked the AF.
Never having used the G1, I wonder...how does the 21mm work (mainly AF) on the (modified, green-label) G1 compared to the G2?
I am not so keen on the 45mm and 90mm (do not to keep gear down, and I will use medium format for 50mm equiv), despite those being stand-out lenses on their own.
The G2 I had was reliable (I thought that was kinda normal until I got my Ms and understood why people have back-up cameras).
How about the G1? Any reason to think it is less reliable than the G2?
And yes, I am looking for a used 21mm Biogon, and MAY trade it for my M6.
Peter
Peter the Leicashop in Vienna has a used 21mm Biogon for the G (incl. Finder) for sale 650 Euros. I believe the G2 has a better AF system otherwise they should be equally reliable.
The 21 (or the 35 and I believe the zoom) will not work with the G1, unless it was factory modified to work with the newer lenses. The modified cameras have a green sticker in the film chamber
I owned and used both a G1 and a G2 for about 7-8 years. Loved the 21mm Biogon. It was always used on the G1 and always zone focused. You certainly do not need AF on a 21mm lens because of the huge DOF. I do not think I ever used auto focus on the 21mm even when shooting it wide open.
Actually, the G1 became my primary camera as it did everything the G2 did but was a tad bit lighter. I came to use the G2 only when I needed the 1/4000th shutter.
I owned both the G1 and G2 and preferred the G1 for it's size/weight. Mine wasn't the 'green label' version, so I couldn't use my 21mm on it but I wish i could have. Never really liked the G2. I hung onto the 21, 45, and 90 to convert to M-mount thru an ebay seller.
If i were you, I'd save the cash on the G2 and find a green label G1. You can also apparently add shims to the manual focus knob on the G1 to give it more resistance when zone focusing.
I curious how did you manage that. G1 doesn't have focus lock and the position of the distance wheel is prone to accidental twist...
I don't find size difference between Gs noticible, price factor is another thing to consider!
Biogon 21mm ah ohh ahhhhoooooo
I can confirm what eric4 wrote: I had my G1 shimmed and the focus wheel is now usable for zone focus or hyperfocal applications.
The tension on the focus wheel of the G1 was a poor engineering design. Many have come loose and lost that tension. Fortunately it is a very simple fix for any camera repair person. My repair cost a can of cold beer since it was done late in the day.
Hmm, my focus dial seems to be well dampened.
Just for giggles, anyone have a link/DIY tutorial on shimmjng the dial?
Maybe mine could be stiffer! First time G user, no clue :)
Bob, love the signature.
Updating it to green label seems to be possible with no tool but the camera. I'll continue on the DIY section - there might be people over there that don't watch here and have valuable input...
Thanks, Sevo. I have a near-mint G1 which I never use, and I have been thinking about putting it up for sale. It does not have the famous green sticker, but I have never cared, since I have the 28mm lens, and see no need for the 35, which in any case seems to have a so-so reputation. The 21, I can't afford, so I don't have a lot of motivation for the upgrade, unless that is important for being able to sell the camera. So, my questions are: is it worth while getting the upgrade? If so, how can I get it done ?
Dez
G1
G1
Hi, i´d recommend the g1 over the second version, it´s way too small and light, the aF system is just the SAME as the other and so will be as efficietn/defficient as the larger sister.
Of course get yourself a green label body since on that you´ll be able to use all lenses excepting the zoom.
Also the g1 is very inexpensive...sometimes a good condtion body can fetch 130 usd!!!!
Hi all,
thanks for the feedback. I am a little surprised about the good vibes for the G1.
Monochrom....that was my line of thought....I could probably get a G1 21mm AND G1 for the price of a 4.5/21mm Biogon. I guess could give the G1 a try. I know the G2 well, so I would quickly know how it compares.
The "update" are just the missing table entries for the lenses, so it is entirely useless if you don't own the 21 or 35mm - or intend to sell the camera (but there, the right label colour will probably add more to the value than the table update).
Factory service presumably did flash the update from a serial terminal, but the entire EEPROM is also accessible right on the camera if you start it in service mode. If you don't mind tweaking a few dozen bytes of hex code with no better tool than the knobs on the camera, you can add the missing entries right in the field.
Hi!
So - I have the lens. Now I need to decide on the body. I have the choice between a G2 body (with dealer warranty) and a G1 body with the update/label. I am leaning towards the G1, for reasons of size. Again, the camera will be used alongside a GF670 and Leica X2...so size matters a bit.
Now my questions that hopefully help to make a final decision:
- Weight: how big is the difference really? The G1 seems to be 460gr, the G2 is listed between 560 (OK) and 630 (too much). I had a G2, but cannot remember.
- AF with the 21mm and 45mm: In good light and normal conditions, is the G1 less accurate? Speed is not so much the thing. I got along with the G2 AF. Are the differences only down to the IR assist in low light, or is the G2 better in good light as well?
- Battery life and cold weather: differences?
Thanks again!
Peter
I used both and I will recommend the G2 over G1 for the following reasons:
1) G2 has more reliable AF
2) G2 dual AF system is more accurate
3) G2 has a more robust body
The size and weight difference is not that big but noticeable.
Hi all!
I settled for the G1 - for size and weight. Should I also decide to add the 45mm and 90mm again, I will get a G2 body.
Thanks for the helpful replies!
Paolo, I read about that Zoerk Heliar. An interesting option, particularly since the Hologon is expensive, slow and takes no filters.
