contax T3 repair
Cutly
9:50 AM
Does anyone knows where to send a contax T3 in europe? My contax need a little repair, and I can't find anyone to fix it in france.
Adresses outside europe could be usefull too.
thanks,
t.
Salut,
En France / Europe je ne peux pas t'aider mais aux Etats Unis il y Mark Hama et Nippon Photo Clinic. Dependemment du probleme ca va te couter entre $160 a $190 (ht) tant qu'ils n'ont pas a remplacer l'unite objectif/obturateur ($500+ d'apres Nippon Photo).
Can't help you much for France & Europe, but in the USA I've used Mark Hama and Nippon Photo clinic. I've typically paid between $160 to $190 for repairs (before taxes), depending on the issue. Replacing the lens & shutter unit is a $500+ expense.
My repairs consisted of a jammed shutter / lens barrel.
Mes problemes avec mes T3 se sont limites aux volets ne se fermant pas et a l'obturateur qui se coince / l'objectif ne voulant plus se retracter.
Merci,
It's just a little problem with the battery : les piles se déchargent beaucoup trop vite !
thanks !
EDIT : I found mark hama's contact, but not nippon photo clinic, would you post it here?
Nippon Photo Clinic
920 Broadway New York, NY 10010-8018
(+1) 212 982-3177
Battery issues can be many things that don't need repair...
Have you eliminated the battery itself as the issue? (aka, do you have a brand name battery in there or a cheap brand?)
Is it something that only happens in cold weather? (you have to keep this puppy warm, though I used mine in the NYC snowstorms recently and it performed splendidly.)
Clean contacts?
Hope you don't have to send it out. Superb camera.
m.
Yes, I changed many time my batterys to be shure, but I didn't tried to clean contacts. I just did it even though they didn't seemed to be dirty at all.
And, no, apparently, it's not the weather, I thought the same way at first but it's not.
How would you clean contacts?
thanks for all.
If I recall correctly, Kyocera NY offers flat rate service ($17x) which covers both parts and labor.
