Contax TVS III plus Nissin flash
marameo
3:36 PM
I have a Contax TVS III and I would like to stress its built-in flash a lot less with the help of a second flash in slave mode. I am wondering if I can consider any flash such as the Nissin Di622 MARK II or I can only use Contax units as the TLA.
Thanks.
Supplimental Flash
Supplimental Flash
I am presently looking to add an external second flash unit to enhance the use of flash on my GS645zi. Assuming that you are looking to use an external flash slaved to you camera's onboard flash, then any flash equipped with a slave trigger should work. If you have a more powerful external flash to use, but it has no slave trigger, then you could add a slave trigger module (Many made by Wein) or you might find the Contax accessory for the T cameras which is a support with hot shoe & slave trigger built in (insanely overpriced new).
