Copal SVA
santino
FSU gear head
1:42 AM
Hi all!
Today I cla‘d my Konica Auto S2s shutter and everything seems to work fine despite too much friction when changing shutter speeds.
I know it depends on how much I tighten the small golden retaining ring but either it is loose or too tight.
Is there a solution to it? Changing shutter speeds before disassembly was smooth...
Thanks in advance!
You may need a little grease such as white lithium grease on the sliding surfaces but be sparing. It is easy to over-tighten the ring I think - a little wobble does not hurt to be honest, the ring mainly holds the other rings not the lenses.
