Correction lens/ eyepiece for Super Ikonta III ?
abumac
9:31 AM
Hi, does anybody know if there is any correction lens/ eyepiece for the Super Ikonta III?
Thanx.
Not sure where you're located, but here in the US it's simple enough to buy a pair of reading glasses w/ the right magnification for $1 and cut it w/ a Dremel tool. You can either cut it to size or make it a little bigger and glue it on the bezel around the existing eyepiece. Might take a few tries to get it right, but since each pair of glasses gives you 2 tries, $2 should do it.
Acrylic glass I hope then :)
For the Iskra I and for a separate optical viewer I have used older (prescribed) acrylic eyeglasses that I had saved. Works well. In the Iskra the "eyepiece" has a small tube inside the top cover where the glass can be fitted in. Check that on the SI.
