W
wlewisiii
Guest
I'm thinking about getting a new lens when I get a VC Meter II from Mr. Gandy, especially since they are on close out right now. I am having a hard time deciding which one to get however.
I have a Jupiter-12 for a 35mm at the present. It's a good enough lens though it could use a relube. The bigger problem with it is that it's limited to mounting on some CRFM cameras. If I get a R2C or even a Contax IIA at some point, I'll need a different 35mm anyway.
OTOH, I have a hard time, sometimes, even seeing as wide as 35mm which makes me wonder if I should even bother getting anything wider? I'm leaning towards either the 28 or the 35 mostly as a result. Anyone want to offer me any advice on this?
Thanks,
William
Thanks,
William
