CV Lens advice
laskadog
2:13 PM
Hey folks,
I have been playing around with a Leica M for a few months now and decided to get an R-D1 to mess with for when I don't have the time to develop film, which is increasingly more often.
However due to the crop factor of the Epson, I need to change my lens set-up a little. I'm going to stick mostly to CV lenses for cost reasons and wanted to know if the following lenses have worked well for you on the R-D1 in the past or if they pose any problems:
CV 21/4 Color Skopar
CV 35/2.5 Color Skopar
CV 35/1.4 Nokton
CV 50/1.5 ASPH Nokton
I might consider othe Zeiss or Leica lenses if they are around the $500 mark, but for now this is just for fun and I'm not going to fuss over corner sharpeness or vignetting.
Any experiences with these lenses would be appreciated.
I had focus problems with my 50mm f/1.5 & sent it back, and wound up buying an f/2 Summicron which is just SO great I can't explain it quickly. Picked up a 40mm Summicron-C as well, also quite cheap, and stuck to the CV 28 f/2 Ultron (a cracking lens) and the 15mm f/4.5 (quite slow, but wide) for wider angles.
Pretty happy with them, though the 15mm is quite prone to purple fringing and the like. Hope that helps,
R!
My 2 cents
My 2 cents
I own all the lenses that you mentioned and more.
My favorite for the R-D1s are
1) CV 28/2 or CV 28/1.9
(The latter is not current production but good if you can find it)
2) Summicron (IV) 35/2
Anything wider you'll need and external finder. If you don't wear glasses you can get the ZM 25/2.8 and use the whole finder for framing. It is an excellent lens. The CV 21/4 is a fine lens, but I would much rather get the ZM 21/2.8, which is arguably the best 21mm ever made.
The CV 35/1.4 has odd bokeh that is not suitable for all subjects and is often written about and I concur. the CV 35/1.2 is way to large and is like a cancer on the body.
The 28mm length is great length for the R-D1 crop factor, the 35mm is good too. But 50mm onwards tend to be too tele for everyday use.
Hope that helps.
If you consider buying used lenses, the 35/1.7 Ultron is worth looking at. I have only used mine with film cameras, and do not have an RD-1. I am impressed with it. I will be using it on my incoming M8 soon. The distance between the rear element and film plane is relatively big for a 35mm lens, and the contrast is low to medium. I believe these are desirable features for use with Digital. I will know soon.
Lens advice
Lens advice
If cost is a reason, consider the Summicron C 2/40. Very nice and small lens and it just fits the 35 mm frame lines.
Hey folks,
CV 35/1.4 Nokton
I too would very much consider the 28/f1.9. My everyday lens. It does most things right. Very suitable for the R-D1. Nice colour rendition. The 35/F1.4 I like too, maybe contrary to other's beliefs I have no issues with the bokeh. Both these lenses are quite sharp wide open, at least for one used to SLR lenses. I have the 21/f4 too. Not a bad lens either, but I tend to use it for B&W, indoors and with flash.
I have read over and over on threads like these that the 40mm Summicron and Noktons (SC/MC) are a great fit for the R-D1's 35mm framelines (more so apparently than most 35s). So much so that I ordered the 'cron which is at home right now, waiting for my R-D1 (in the mail). I'm sorry I don't have anecodital advice to give (so take it for what it's worth), but I really suggest taking a look at results for both lenses. I only checked out the nokton after I ordered my 'cron, and regret it a little. Both lenses have nice bokeh, but the nokton's really stands out! Also, the 'cron is apparently sharper in the center - though that evidence is based on a test I read, not did myself (so again, take it for what it's worth). Hope that helps!
I'd agree that a 50 can be long on the RD1 for walk around and general use. I like the CV 21/4 (some M8 photos here.
Not sure if you'd need an external finder would be needed with the 21 on the RD1 (I don't need it on the M8).
I often use a compact Canon 28 or CV 40/1.4 on the RD1.
i liked the CV 28mm/1,9 very much until i happend to receive a biogon 25mm for free (thanks to my employer giving away a special bonus).
nowadays i preferred the CV 28mm/2.0 because of its smaller size. the 1.9 is just that little bit too bulky for my taste (as is the biogon ... but that one is a true keeper cuz of its optical qualities).
I have the 40 CV, and it does give very weird bokeh in the right conditions, such as a strong backlight.
I also have the 35 2.5 Skopar, Nice little lens, got it to see how it compared to the 40 .... Its a tough call.
I have the 15/4, and it has not captured my heart.
Dave
