Stephanie Brim
Mental Experimental.
Before I go on with this post, I'm going to let you all in on a little secret: I am completely off my rocker. This may or may not come as a shock to you, but it will help if you keep that in mind for the remainder of the post.
I'm going to need to build a darkroom. Literally. From the ground up. There is no place in this house that is actually suited to making completely light tight and so my only other option is pretty much building a small area either inside my current room or outside the house that will work as a darkroom.
This is an insane idea. I don't know any carpenters. I know an electrician and someone who can pass as a plumber, but no carpenters. Nor do I have tons and tons of money to spend at this time on this venture. Right now, I pretty much just want to build an enclosure that would be light tight and afford me the space to at the very least print a few of my own photos. I pretty much know the supplies I need for a good working darkroom...but how would you go about actually building one?
Realistic, space-saving, cheap ideas wanted. I haven't Googled this or anything yet, though. Figured I'd ask here first. Any insight as to how I can do this would be appreciated.
