Darkroom Question for Darkroom Experts
Superdan138
6:15 AM
I own a M6 and have 2 lenses (Noctilux and 35mm Summicron). I only shoot film (mainly B&W) and am really getting more into photography. But I need to rely on others to develop and print/enlarge my photos at this current stage. I want to get very high quality enlargements of my negatives/photos and start a darkroom, but space is limited in my current house. I used to develop and enlarge my photos back in high school and want to get into it again. My 2 questions are....what do I need for B&W enlarging of my negatives and also what are some very good names of enlargers or specific links to good deals on enlargers? thanks...
-Daniel
Well I'm no expert but I'll chime in anyway:
- Enlarger, I use Meopta's, Czech make, quite prevalent in Europe, not so sure in the US but very well built. The Axomat is 35mm only and perfectly decent (I use one), Opemus is 35mm to 6x6 and Magnifax (?) is up to 6x9.
- 3 dishes to develop in, I have two sets, one for 10x8 papers and one for 16x12, the latter are big so having smaller dishes is good for the majority of the time. Tongs too.
- A decent timer to keep an eye on your exposure times.
- A decent enlarging lens, I have an El Nikkor 50mm f/2.8 for 35mm, cost me a measly £22 and it's brill.
- A decent easel/masking frame. LPL is good, I have their 17x14 easel, 2 bladed but sturdy and reliable.
- Measuring cylinders to measure your dev, stop and fix
- Storage cylinders if you don't exhaust all your stop and fix in one sitting
- Darkroom light is handy but not essential
- Somewhere decent to hang your prints up to dry
- Nearby sink is helpful
Those are your essentials.
As for enlargers, there are many and it's like asking 'what's the best 50mm?' but bang for buck, Meopta -- sturdy and reliable and they come in condensor type (b+w) or colour heads (colour and b+w)
My Axomat 5 set me back a huge £10 and my Opemus 5 a stonking £4.99 🙂
Vicky
Its the lense that matters pretty much. Schneider, Rodenstock, Nikkor... I guess Rokkors too, those are known to be good. Dont know if theres much difference even with the cheaper ones. Sure you can try to get great condensor lenses but it wont be the main thing.
Just get an enlarger you can use easily and enjoy using I would make it a color head or multigrade head if you mostly shoot black and white. I dont think that the enlarger would be the bottleneck really, so just get one that is nice to use.
I would suggest using two fixers, older and fresh. Then a good wash, so 4 dishes + one for washing or a dedicated washing system.
At least for me, the tones are the "hard" part, I think that the limiting factors for sharpness and resolution have already happened at the time of exposure.
Lilserenity has it pretty well covered but on this side of the big pond "dishes" are "trays". You'll need a funnel or two, a mixing tub of some sort (a cheap plastic pail will do) and containers to store chemicals. Get a plastic spatula or slotted spoon at the dollar store for stirring. I use two liter soda bottles such as Coca-Cola comes in. Off brand or store brand is often 69 cents a bottle so it's pretty dumb to spend several dollars on special jugs at the photo supply. Either drink the stuff or dump it down the drain and you're still money ahead. Yup, they say it's best not to store it in the light but you DO NOT NEED expensive brown bottles. Just store them in a closet or dark room.
A Saunders four blade easel is nice so you can center your prints on the paper.
Some people like using print tongs, others don't. Fiberglass screens are ideal for drying prints. If you have some reasonably fresh print developer in the tray just float your stop bath tray in the developing tray. It makes a good cover.
I'm still using an Omega B-22 enlarger that I biought new in 1964. I have an 80mm f/5.6 Schneider Componon and a 50mm f/2.8 El Nikkor on it.
Keep your eye on local buy and sell internet sites like CraigsList and go to thrift/antique shops and garage/lawn/boot sales. Enlargers can often be found for very little. ($20) If you get lucky, you may find a whole darkroom setup as many people are currently abandoning them in favour of digital.
Once you get set up, it's a whole lot of fun.
Being a bit of a darkroom " junkie" (which explains 3 current enlargers) I would suggest the best 35mm enlarger made. A Focomat Ic, late version with the tall upright post and a filterdrawer. This is known as a Ic Color. The lens, which should come with the enlarger, is a Focotar-2 50f4.5 .
It will only do 35mm - but nothing before of after has surpassed the quality. You will need a good easel, Saunders Pro 11x14 and if you want to go bigger, the Saunders Pro 16x20. They are both 4 bladed easels on a 1" base for the Focomats auto focussing.
With enlargers, the quality of the end result is dependent on the lens (always get the best) and evenness of illumination - and alignment.
I have used Focomats for 40 years, both the Ic and the IIc's (the latter for 35 and 120 negs. I have also used a variety of enlargers by Beseler 45/s,Omega D6 etc - they are all good, but nothing beats a Ic properly set up for 35mm negs.
And dont buy expensive "photography plastic", or at least consider the cheaper alternatives. You can get the trays and the mixing cans by buying normal kitchen stuff...
If you're in the US, I might look for a Beseler 23CII or 23CIII (though basically the same as the 23C, they are newer and should be in better shape). They're all over the place for a decent money, have tons of accessories on the used market, and are still made. You can get a VC head or a condenser head.
The Nikkor 50/2.8 N is a good affordable lens to start with. Again, you can pick up new ones nowadays for $50-60. Used even cheaper.
I'm not saying that this is the best setup, but it's (very) good quality to start out with, readily available, and affordable. You might never move on from it.
Things might be different if you aren't in the US...
You can always find things for darkrooms rather cheap in local "Buy and Sell" type of papers as well as on Craigs list.
With trays - always get one size up from the printsize you are planning for (i.e 11x14 for 8x10 prints and 16x20 for 11x14 prints). It allows you to "rock" the prints in developer and hypo without having liquids sloshing all over the place.
You need two timers, a timer for the enlarger - digital is best and one that counts backwards to zero in 0.1 sec increments. Easier to dodge and burn and one or two Gralab 300 for developing and fixing.
Lots of graduates and dont go too small either. At least 2-3 of 1/2 gallon or even better 2.5 liter versions. Dedicate one set for developer and the other for fixer.
The good thing is that darkroom equipment lasts a long time. Both my enlargers, trays. graduates and beakers are between 15-20 years old. I occasionally replace the fix-beaker when it gets too "crusty" (about once every 5 years).
Darkroom stuff is rather impervious to "fashion" trends in photography. If it worked well in the 60's - there is probably no "new" and "improved" item that you have to have that would make any difference today.
I agree with the "Dollar store" for getting darkroom accessories. As well, try to find a focomat 1 c and get a focotar-2 lens for it; you will get super duper quality prints. I picked up my mint focotar-2 for a wink and a smile; I found my focomat 1 c for free. Tom A taught me that rewiring it was dead easy; and it was. A perfect enlarger for 35mm, which I shoot most of the time.
Buy used for almost everything and learn to bulk load film.
I usually recommend a Durst m600 as an inexpensive first enlarger, it can do 6x6 cm as well as smaller formats and sets-up and packs away quickly. If you do go to medium format, you'll want a second enlarging lens and I recommend the 80mm Nikor for medium format, the 2.8 Nikor is a great lens.
That said, I've been enjoying my Leitz Valoy II for 35mm, it to is very simple, gives great enlargements, though I generally keep them small, 8x10 in. for 35mm format. This enlarger does not have a bellows, using a helical arrangement instead, and the condenser sits atop the negative. The Valoy IIc has a filter drawer but you can trim to round and set filters inside the housing above the condenser on earlier models. They are easy to replace while working.
If you do buy a Valoy, a ratty power cord is VERY easy to replace and you should (read must!) get the negitive carrier with the enlarger.
Whatever enlarger you buy, if it has a condenser, check it for chips and scratches.
I like these enlargers for the mono-column construction and ease of use. My Valoy came without a baseboard and you might save bucks looking for the same, though a good one should not be expensive with some looking about. I had a 3cm granite slab tapped for the Valoy column mount and it is a very solid, stable tool.
You will want a good polycontrast filter set. Many of the enlarging papers are VC, even the fiber based and this is a necessity, unless you have a lot of Kodak CC filters available. You can use under the lens mounts for PC filters but above the negative is better, IMO.
Canned air can be important and there are good reusable handhelds available from Microtools which use disposable co2 and nitrogen cartridges.
A good camel hair brush for negatives only and negative cleaner and scratch 'remover', like the Edwal products are well liked and useful.
A grain focus tool is very handy if not a necessity but if you wear glasses, be prepared try out several to see what works for you.
You'll want to decide which type of tanks to develop film in, metal or plastic. Since you are talking 35mm, I suggest metal tanks, no smaller than two reels, either Hewes or Nikor.
If you go plastic, Paterson all the way. They will also do 127 and 120 if you do move into medium format.
Don't use stop bath with films and don't use shorter developing times than 5 minutes.
If you use HC-110 or Rodinal, use syringes to measure concentrate amounts. D-76 is excellent as well and you can mix your own, as well as Parodinal
Use Photoflo or similar for film development final wash, period.
I suggest you find an old Gralab swept hand timer for the wet area to time with, you'll want something easy to see and set.
You will also want a safelight to keep track of what's happing in the developer tray.
Don't use your hands to move prints from one chemistry to another, some people develop bad contact reactions to chemistry and it's not good to be going from sink to paper safe/negatives with iffy hands.
Buy new bamboo tongs and first thing drill a small hole in the rubber/plastic tips and pin them to the tong with bits of bamboo skewers or toothpicks; loose ones falling off while working are a pain.
You can use new dishpan basins for water and holding baths. Use a HCL after fixing, with a 5 minute low flow wash or large tray holding bath between chemistries and consider adding Selenium toning to your line if doing fiber-based prints.
You need a good chemistry thermometer, buy a good glass one (or two) with a holding clips for bottles. I have several good metal probe type tools but for mixing I prefer kodak glass, they are more accurate. If you do buy the metal type, consider spending extra for a colour chemistry one. The build quality is better and the greater range is handy.
Pyrex mixing cups, in all sizes from Walmart, are very useful and half and gallon size pickle jars are handy for mixing chemistry and can do storage as well but always use some Saran Wrap between the lid and contents.
Melamine kitchen spoons will do for mixing tools and buy both plastic and steel measuring spoons as well. The oblong metal spoons are handy for getting into small jars of chemicals.
You should seriously consider mixing your own chemistries. It's easy enough to do and there's tons of info in print and online. APUG is a great place to start online and "The Darkroom Cookbook" will be a good first darkroom book, even if you only mix your own D-76 and paper developers.
A small Harbor Freight digital scale is available that measures in grams, ounces, grains, etc for about $10 and if you measure in grains, it can be good enough. For really fine measurements in small amounts, a gunpowder scale is accurate to .10 of a grain; there are 7000 grains to the U.S. pound.
Ansco 130 is a wonderful paper developer and it gives blacks that easily rival Amidol developers. It stores a year or more in solution, I've used it two years old before and will last weeks in an open tray, even if it goes black as coffee.
Ansco 130 can also be considered a 'universal' developer as it will do film too.
Chemicals can be had at several places and though it might cost more to do this initially, most of them, if stored properly, will last forever. Even Glycin, needed for Ansco 130, bought fresh from Photographers' Formulary, will store well in the freezer in it's Nalgene bottle and I've been working from a bottle three years old that shows no sign of weakening. The Chemistry Store is also very good to deal with, in my experience and their pricing on Sodium Sulfite in bulk is very good, a bit over a dollar a pound, before shipping.
http://www.photoformulary.com/
http://www.chemistrystore.com/
Wine bottles with plastic corks are good for storage of solutions and if you mix your own, you can adjust the amount of solution to the size storage you use.
Use distilled water from Walmart for mixing chemistries and inline water baths. At about .53 a gallon, it's ideal and the amounts needed won't brake the bank.
Stuff you can make
A plastic hanging wardrobe is useful for a film drying cabinet and you can modify it with AC filters, a PC fan wired to an old cell phone charger and duck-tape to circulate air.
You can also use a PC fan, cell phone charger and some magnets to make a good magnetic mixer, with a simple wood frame and acrylic top. You'll might use a light dimmer to control the speed, I haven't tried that as I had another device for control. You can get the proper lab 'stirs' from eBay in several sizes and the pickle jars I mentioned earlier are excellent for mixing duties.
PS. You don't need running water in your darkroom. Use the Ilford method for film and deep water baths for prints.
You could do hybrid. I develop at home using just a changing bag and a wine box with the chemicals in it. Then I digitalize the negatives, and post process on PSE6. If I want a print I sent to Costco. I find I have negative control and digitalization control and no darkroom. If I feel I want to do a special negative wet print I go to a public darkroom and print it there.
Also don't be afraid to have more than one lens to use with a particular film format for a different "look".
I have a top quality six element 80mm f/5.6 Schneider Componon lens for medium format and it's extremely sharp. You can clearly make out the grain of fine grain film on an 8X10 print. It's a great lens for landscapes, products, buildings, etc.
I also have a cheap three element 75mm f/3.5 Spiratone lens. An 8X10 or 11X14 print looks sharp enough but it doesn't quite resolve the grain. (or fine wrinkles on your girlfriend's face)
http://thepriceofsilver.blogspot.com
Yeah, let me throw in with John--I develop myself, scan, process in Lightroom, then inkjet print. Total supplies beyong developing are:
Nikon Coolscan
Epson 1400
MIS black inkset
QuadTone RIP software
Nice paper
That's it. I can touch all of my supplies from where I'm sitting--it's all on a small table--and I don't need to do it in the dark. And the prints look great. Not the same as wet printing, but not bad at all.
There are two enlargers in the classifieds right now. One of them is mine. Try it on the cheap at first so you can get your money back through resale before you go for the big bucks.
Also, calculate how much you will use it on a cost per print basis. A local or mail order lab may be just as quick and cheaper.
Working in a darkroom is fun but can get long and tireing.
If you have a young family they may not appreciate all the hours you spend in there either.
Just some thooughts. I'm sure my pix and standards are not as good as yours so I am selling the darkroom and going for a scanner.
Actually I'd rather eliminate wrinkles in the original exposure on the film, where a poorly corrected lens spreads the highlights into the shadows. A poorly corrected lens on he enlarger spreads the shadows into the highlights, a much different effect.
I'm sixty-six years old, my "girl"friends are now "lady"friends, and most of them are well past the point where a cheap lens is of much help. I have no idea of whatever became of those twin girls, but they'd be closing in on sixty years old themselves now.
I also have very limited space for a darkroom. I picked up a used 12x16 Nova slot processor which really saves space. Ansco 130 lasts for many weeks in it, and makes for quick sessions without having to mix chemicals each time.
The 4th slot in the model I have is a print washer which is very handy for RC prints
There is so much great advice here. That's why these forums work well. May I add..... I found a darkroom lab close to where I live (Sydney) and I am able to use the darkroom's complete facilities ( I book ahead) for a cheap hourly rate price. I pay for my own film and paper (fomopan paper usually) and the chemicals are free in the hourly rate I pay. My point is more that the darkroom is there, plus the owner is happy to be a guide, add comments and direct you. This is invaluable and saves you time and money. Of course, depending on where you live you may not have access to a local darkroom like I do. Then your own darkroom would be the obvious choice. My second point is that it's good to develop "good" habits in the darkroom or processes and procedures that will again save you time and money, so you can really enjoy your creative art and photograph more and more meaningfully. This is where using or assisting even in a good darkroom proves very helpful.
