Dektol dilution?
grapejohnson
5:39 PM
I like developing my film in a dilution of 1:1 (D76) because I get sharper pictures, can be a little more lax with dev time, and it conserves chemicals. Are the benefits the same with Dektol and paper? If I diluted to 1:1, would I have to double the dev time?
You develop B&W prints by visual inspection so it is different than film development by closed small tank.
Dilution rate is 1:2 with Dektol.
You might see the image come up sooner but not by much at 1:1 but thats all.
Try it you might like it but my experience says that following Kodak's recommendation is usually the correct way to go.
does it yield sharper results?
I did not see any nor change in contrast but it has been many years now since the trial run.
Like I said try it and find out, a bit of Dektol and a sheet of photo paper is all that your expense is going to be not including your time.
I've used it at even lower dilutions 1:4 or 1:5 for 4-5 minutes as a last resort for problem negs with a resulting decrease in contrast and shadow density.
