Delta 3200 + Diafine
smiler
7:24 PM
Can you dev Delta 3200 in Diafine and if so what EI do you shoot it at? Would you knock it down to 1250 like T-Max 3200?
Smiler
Delta 3200 shot at 2000 per my box.
I have done it and got pretty good results. In my opinion Diafine controlled the grain and contrast pretty well.
Several years ago David Carper sent me a few rolls of 3200 for me to test on Diafine.
I ran a standard test shooting walls and some scenes in the 400-6400 range, then developed 3+3 in Diafine.
I got 1200-1600 out of it only.
DDX, Clayton F76+, or Xtol would do a much better job allowing you to go up to 12800 or so
The best developer for 3200 is DDX in my experience, and I shot it at 3200. Not bad for that speed. Quite good, actually. With Diafine, however, you actually lose a stop or so from what I've heard/read.
I checked my Diafine box and it doesn't list Ilford 3200. Let me know how you like it, please. I have four roll of 3200 I haven't used since I ran out of DDX so I'm in the same boat. Excellent developer DDX is but a bit pricey and can be hard to get sometimes. I switched to Diafine and Rodinal from the one shots (well, Rodinal is one shot but you can develop lots of rolls at 1:50). When I use the 3200, it will be Diafine, so I would be interested in your thoughts. There's nothing on Massive Dev Chart for this combo either.
By the way, my personal favorite is Tri-X in Diafine at 1000-1600 for high-speed.
Ah good ole Tri-X... looks great in everything. I think you can actually soup that stuff in pepper pot soup and it would look okay.
box
box
My box doesn't have 3200 on it either, though Rover's mystical box does (?). I haven't bought any 3200 as yet as I wanted to check out the 3200/Diafine response before going for it.
I'm mostly using FP4 and HP5 in D76 and Tri-X in D76/Diafine.
Smiler
