Delta 3200 in Xtol
Jockos
9:44 PM
Sweden
Hi!
I recently made a switch from D76 to XTOL (actually the Foma equiv). This winter I'll be shooting some Delta 3200, and I wish to know if anyone has some good times for this combo.
I want to expose at 1600, develop in 20C and 1+1 dillution. I found times for 24C at the devchart, but none for 20C.. Googled this for a while without success also.
I did one roll for 20 min with gentle agitation today that's hanging to dry right now. From what I could see it looked pretty good, albeit slightly thin.
The Massive Development application has a temperature conversion utility. I think that you can also find a chart/graph @ digitaltruth.com. I routine develop non-critical work using the temperature conversion utility rather than waiting for temperature to reach ideal. Usually, I only do this within a couple of degrees of my ideal temperature.
I usually use TMax Developer for fast films, but XTOL should work nicely.
That's how I ended up with the 20 mins 🙂
Xtol is a good choice for Delta 3200, since it's a full-speed developer. I've only processed Delta 3200, shot at 1600, full strength, not 1 + 1. It works well full-strength at 20 degrees C. You may have to experiment with a few rolls to find the best time when using Xtol at 1 + 1.
Jim B.
I didn't have great results with Xtol, which I use for every film except D3200. DDX worked better for me, giving speed but not too much grain.
I develop one speed faster than I expose, usually exposing at 1600 and developing for 3200.
20 minutes, Canon 9000F, a little PP:
No problems with shadow details, and highlights seem smooth enough!
Truth to be told, German wasn't my favorite class.. Will have a look though, thanks!
No worries. My German is long since forgotten. The numbers are in English. Grinning. You will notice that there are times for both small tanks & normal agitation as well as rotating, continuous agitation, as in a Jobo processor. Dilutions from straight to 1:3 for each method. Have fun!
Wayne
