Dev very old exposed 120
BobBill
2:05 AM
My photo-mom passed couple years ago...I inherited her 620 and 120 exposed BW Kodak roll film some 12 rolls, ...no idea of anything, save BW and approximate exposure dates say 1936 through 1948. Were in dresser drawer.
Any hints as to developer, time etc. I have Ilford, HC 110, maybe some D76 and can of Rodinal and mixed Altra.
If it's Kodak I'd guess its Verichrome (ortho). Verichrome originally was an ortho film until the late 50's. I believe it was ASA64 at the time.
D76 should work fine. Unfortunately I don't have any data. You can research a little or try one roll as though it is Verichrome Pan. There could be a difference in time though.
I found some data for Verichrome (ortho) which was made prior to 1956. In 1956 it changed to panchromatic. When I was a kid learning to process in the 50's I shot Verichrome and ran it under a RED (not orange or yellow) safelight. Red was safe because it was color blind to red.
The data I found was 17 minutes in straight D76 at 68 degrees f. If you have a red darkroom bulb you can do it by inspection if you know what to look for on the film. If not bony bother because it takes experience to do it correctly.
If you can find Kodak Anti-Fog 1 use one tablet in the developer. Benzotriazol or Edwal Orthozite are essentially the same. With or without you're going to have very dense fogged neg.
This is assuming its Verichrome ortho.
Gene W or M on Photo Net recommends HC-110 for 'found film' he says it is the best to reduce fog. You can look for him on the Internet where you will find lots of information on developing these films.
His link is above.
