Developing 120 and 135 at the same time
jcrutcher
5:49 PM
Phoenix, AZ
Hello, a few weeks ago I asked if you can develop two brands of film together and many RFF's suggested that would not be a good idea. This question is can I developing a roll of Tri-X 120 and Tri-X 135 in the same tank using D76 at the same time and temp?
Thank you! Jim
Thank you! Jim
Yes........
No problem, if you have a tank that will take them - the most common inversion tank size is height limited to two 135 reels, so you'd need a bigger (three 135 or up) tank.
No problem whatsoever. And even mixing brands and ISOs isn't generally a problem since most classical 100 and 400 films all need the same developing time in D76 1+1.
