p.giannakis
Pan Giannakis
I am using HC-110 and i want to use Dilution H (1:63).
Has anyone developed it in dilution H? How long did you develop it for?
charjohncarter
Yes, I shoot TMY-2 at 200 and develop in HC-110h for 11:15, 30 seconds initial agitation, then 3 inversions at 10 minutes, then 6 minutes, then 2 minutes; 68 degrees F or 20 degrees C.
p.giannakis
Pan Giannakis
Fantastic. Thank you
Raskolnikov
Shoot it at 250 and develop it for 12:30 m. Agitate for 10 sec every minute.
KenR
As everyone's thermometer and water are a bit different, you are going to find a wide spread of times. I use 400Tmax at 400 and develop with HC110 1:63 for 11 minutes at 68 degrees with initial agitation for 30 seconds and then 5 shakes every minute. Unfortunately all of the advice that you receive should be a starting point and not an end point - you have to find what works for you.
