Diafine, Film Speed, and fogging
XAos
12:24 AM
I know as a general rule, faster film speeds are more prone to heat fogging, but how does Diafine's speed increase and constant contrast developing play into this? If I'm shooting Tri-X at 1600, does it fog faster/more than if I were shooting it at 400? Will it fog more or less than color 800 speed film? I keep color 800 in my Stylus, and it stays in an an un-airconditioned building for long periods of time. I try to change it out once in a while, but how long, how hot, and how does diafine affect all this? It seems like constant contrast would tend to work against the tendency to fog, but I also know that the system will break down (say if you accidently shoot it at ISO 100 because you forgot the camera defaults to that if there isn't a DX label).
I am not exactly sure I follow all the above but Diafine, like all other developers I know, will not save film damaged by environmental factors.
Tom
Yes, but you shoot it at 1600 and develop in diafine, will it fog like ISO 1600 or like ISO 400?
Tri-X will fog like Tri-X. It doesn't matter which EI you assign to it.
shooting like 1600 means underexposing by 2 stops.
Tri-X will fog the same way if you expose it normally, or over-underexposed.
