ampguy
Many folks stop down as much as possible to sharp photos. However, in several cases, due to diffraction, you may be getting less sharp, lower resolution, and higher noise photos as you stop down.
Here is what is going on:
as you stop down, the light rays are increasingly hitting the edges of the aperture blades instead of going through the center directly to the media.
Depending on the wavelength of the color, the photons of light hitting the aperture sides tend to diffract over multiple pixel pitches or on film, onto multiple emulsion elements.
The result of the diffracted light projecting over multiple pixel pitches results in loss of detail, and a smoothing or blurring effect, similar to the effects of high iso noise.
There are online diffraction calculators, and overviews is here:
http://www.cambridgeincolour.com/tutorials/diffraction-photography.htm
With the Leica M8, I find that going beyond 5.6 with most lenses can start to show diffraction, which makes the fast 1/8000 shutter very useful.
Independent of diffraction, the best optical resolution for most of my lenses also happens to be between 2.8 and 5.6, which works out well.
