Dirty blades
dxq.canada
9:07 PM
Woodbridge, Ontario, Canada
I took apart a Chiyoko Super Rokkor 45mm LTM lens to tighten the loose aperture ring.
Along the way I took apart the aperture ... tons of brown crud around the upper and lower pins. This is the part you can't see if you do not take it apart, no Q-tip will get under there.
These blades would not have any lubricant (maybe Moly), and not exposed to any grease from the helicoid, so I suspect it is an accumulation of rust/corrosion particulate that floated its way into this area over the past 60+ years.
Almost all old lenses I have seen have lubrifiant on blades. This one is not something unique. Over years it oxidized and turned into gunk.
