Do you know of a camera like this?
68degrees
8:20 PM
USA
Ultra Compact (like the size of a 7sII or Olympus 35 RC.
No meter
fixed lens
Coupled rangefinder
Manual Exposure settings both shutter speed and aperture
auto cocking shutter with film advance
Good lens
35mm film
Cant be a folder
Anybody? Did such a camera ever exist?
By 35mm, do you mean the lens or film format? If format and not lens you might look at the Olympus 35-S and 35-S II. 45mm/3.8, 48mm/2.8 and 42/1.8. Great Zuiko lenses.
Also, if 35mm lens, Olympus 35 wide (either with or without selenium meter.) Much less common than the cameras mentioned above.
Yashica Lynx 14 or 14E. Although it has a meter, it works w/o a battery all manual and the 45mm f1.4 lens is dynamite!
http://www.cameraquest.com/yaslyn14.htm
Edit: realize you said ultra compact, the Lynx 14 and 14e are not compact, but maybe the Lynx 1000 or 5000 are more compact and can be all manual??? Anyone? Russ?
None of the early fixed-lens Yashicas were what I would call compact, and all were quite heavy, in my experience. The GX and the CC were the ones most similar in size to what the OP gave as examples. The sticky widget will be the manual mode for both aperture and shutter.
Have you discounted the 35RC? Fits the criteria but has limited speeds.
If a rangefinder is not a priority (I know it is in your list) then a Petri Color 35 should fit the bill.
No meter
fixed lens
Coupled rangefinder
Good lens
35mm film
Cant be a folder
I'm sure there's some older camera out there that meets this spec exactly, but I don't want to work that hard.
For this sort of thing I grab the Rollei 35S and eschew the rangefinder, or I fit the 40mm on the Leica CL. Just ignore the light meter on both of them.
Olympus QL17-G-III with no battery. Seriously.
It's not the smoothest handling in manual mode, but it's got all the features you seek.
And, add the little Voigtlander meter in the hot shoe for a complete package.
