bigdog
Two seperate questions:
1. I always adjust the contrast and brightness of my negatives after a scan and sometimes doge and burn. Which set of adjustments should I do first (adjust contrast/brightness first or dodge/burn) and does it matter?
2. Does anyone have a good technique for removing a long scratch that runs across the full fram of a black and white negative? Ice won't work here obviously!
P
Peter
Guest
Hi bigdog,
This the workflow that works for me and I acquired it by trial and error (too lazy to read the whole PS 7 manual):
1. Crop the edges
2. Adjust contrast and brightness
3. Remove dust spots and scratches with healing tool
4. Minimal unsharp mask
5. Dodge and Burn
I hope this works for you as well.
Regards,
Peter
1. Crop the edges
5. Dodge and Burn
Regards,
Peter
bigdog
Peter,
Thanks so much. My old version of Photoshop didn't have the healing tool and I got used to using the eyedropper and paint brush tools to deal with spotting and it really didn't work well for scratches. I can't believe how well the healing tool works...thanks again!
P
Peter
Guest
My pleasure! You really should upgrade to at least PS 7 as the healing tool is indispensable for film user IMHO!
Patman
Their was an old trick used with scratched negs when printing on the enlarger, not sure if it will work on a ned scanner but it might be worth a try. We used to lay down a light coat of vasoline & lightly wipe it off, it would fill in the scratches, sounds crazy but it worked.
oftheherd
Patman said:Their was an old trick used with scratched negs when printing on the enlarger, not sure if it will work on a ned scanner but it might be worth a try. We used to lay down a light coat of vasoline & lightly wipe it off, it would fill in the scratches, sounds crazy but it worked.
As did nose grease according to the old books and magazine articles of the subject. I admit I never tried it myself.
foon
that's pretty grossoftheherd said:As did nose grease according to the old books and magazine articles of the subject. I admit I never tried it myself.
back alley
IMAGES
