kshapero
South Florida Man
When using a CV 35mm/1.4 lens (or any other legacy lens) on a Micro 4/3 camera does Image Stabilization make a noticable difference?
hub
Crazy French
I would recommend using it. Don't forget to set the focal length in the IS settings so that it is calibrated properly.
sebastel
coarse art umbrascriptor
yes.
(10 char)
(10 char)
kshapero
South Florida Man
How many stops different? I can usually get a good shoot of a stationary subject at 1/15. So with Is can I get a good shoot at 1/4?
uhligfd
Well, maybe not quite that long (1/4) and sharp ... The 35mm lens has an angle of view as a 70 mm full frame lens, so that would be hand held at down to about 1/60; and IS might help you hold the lens at 1/15 as you said, but better not bet on less; just up ISO and you got the shot ...
And of course, why do you ask? Try a few shots at several speeds and then you know your personal limits here: your heart rate etc play a role, your holding technique, wind, etc etc.
Try for yourself, please!
